I need to put the content of my *.cu and *_kernel.cu files into a DLL.
I work with VS2005 and the QT plug-in to keep my applications multi-plateform
I create a QT library project to produce my DLL and I use a QLibrary object to retrieve my functions:
Qlibrary myLib = new QLibrary(“mycuda.dll”);
myLib->Load();
MyFunction myfunction = myLib->resolve(Wrap_MyFunction);
Using the “export” syntax…
extern “C” void MyCutDeviceInit();
extern “C” MY_EXPORT void Wrap_MyCutDeviceInit()
MyCutDeviceInit(); // this function calls the innermost CUT_DEVICE_INIT();
… I’m able to export all the functions I need except for the ‘timer’ functions
( and a few others like CUT_EXIT() )
Someone could please tell me why ? Since I can export ALL my computing functions (no matter the number and the kind of parameters, no matter how complicated they are) I guess it is just impossible to call timer functions from an ‘outdoor’ DLL.
I’m I right ? Any other idea… ? External Image
Many thanks
David
