How can I use the 'cutCreateTimer' function
Hey!
How can I use the ‘cutCreateTimer’ function? I get the error:
Error: 5error LNK2019: unresolved external symbol __imp__cutCreateTimer@4 referenced in function _CuAddVector cuda.obj
Is there a special header file or lib, that I have to include? It does not work with cutil.h.
Thanks in advance!
when I’m using a timer, I use cutil.h and cutil32D.lib and it works fine.
Hope it helps !
Hi!
Thanks for your answer! I use both of them, but it still doesn’t work. I can compile the cu-file (where I used the function) without errors. The errors appear, when I build the solution or project.
Ok, now it works! External Image
I forgot to add cutil32D.lib Project->Properties->Configuration Properties->Linker->Input->Additional Dependencies.
