After monts of working on a one project, I needed to play a little bit with a smaller program from SDK file.
I moved it to separate location, recreated a new project file for my VS2008 (didn’t want to use original ones). Now I am trying to compile everything.
I set additional directories:
include directories for nvcc: “$(NVSDKCUDA_ROOT)\common\inc”
lib directories for linker: “$(CUDA_LIB_PATH);$(NVSDKCUDA_ROOT)\common\lib”
both environment variables exist and are equal to:
CUDA_LIB_PATH==C:\CUDA\lib
NVSDKCUDA_ROOT==C:\Documents and Settings\All Users\Application Data\NVIDIA Corporation\NVIDIA CUDA SDK
compilation goes well, but I cannot make it to link everything together.
1>Linking…
1>LINK : warning LNK4098: defaultlib ‘LIBCMT’ conflicts with use of other libs; use /NODEFAULTLIB:library
1>scanLargeArray.cu.obj : error LNK2019: unresolved external symbol __imp__cutCheckCmdLineFlag@12 referenced in function “void __cdecl __cutilExit(int,char * *)” (?__cutilExit@@YAXHPAPAD@Z)
1>scanLargeArray.cu.obj : error LNK2019: unresolved external symbol _cudaGetDeviceProperties@8 referenced in function “int __cdecl cutGetMaxGflopsDeviceId(void)” (?cutGetMaxGflopsDeviceId@@YAHXZ)
1>scanLargeArray.cu.obj : error LNK2019: unresolved external symbol _cudaGetDeviceCount@4 referenced in function “int __cdecl cutGetMaxGflopsDeviceId(void)” (?cutGetMaxGflopsDeviceId@@YAHXZ)
1>scanLargeArray.cu.obj : error LNK2019: unresolved external symbol ___cudaRegisterFunction@40 referenced in function ___sti____cudaRegisterAll_49_tmpxft_00000ec0_00000000_6_scan
LargeArray_cpp1_ii_839760fd
1>scanLargeArray.cu.obj : error LNK2019: unresolved external symbol ___cudaRegisterFatBinary@4 referenced in function ___sti____cudaRegisterAll_49_tmpxft_00000ec0_00000000_6_scan
1>E:\CUDA\PrefixSum\SDK\Debug\SDKPrefixSum.exe : fatal error LNK1120: 26 unresolved externals
Any ideas what I missed?
