How to read fan speed from fan itself (FAN_TACH)
Hi Sir/Madam,
I can set pwm to change fan speed by “/sys/devices/pwm-fan/target_pwm”
But how to monitor current fan speed that feedback from fan_tach pin.
cur_pwm is also only Xavier pwm output information (even if I don’t connect a fan, it still has value), could we get fan speed that is from fan itself.
I check the fan speed should be monitored by “FAN_TACH” pin, how could I get current fan speed information?
Thank you
You could use below node for the fan rpm.
cat /sys/devices/generic_pwm_tachometer/hwmon/hwmon1/rpm
Hi WayneWWW,
Thank you
Hi @WayneWWW,
Thank you so much for pointing out the file (/sys/devices/generic_pwm_tachometer/hwmon/hwmon1/rpm) from where fan speeds could be obtained in a Jetson Xavier NX board.
My question is: Does the file contain the fan speed as RPM or as 10 times the RPM or as 100 times the RPM?
Thanking you in adavnce,
Regards
Hi EdmundRay,
Please help to check this issue. Thanks
