How to read/write iova(I/O Virtual Address) of PCIE endpoind mode
Hi Nvidia,
I’m testing the endpoint mode of PCIE,
I add the patch of the topic.
The patch work fine and I got the iova of EP side.
But how cauld I read/write the IOVA of PCIE.
wilson@OrinNX-EP:~$ sudo dmesg | grep pci_epf_nv_test
[  522.603944] pci_epf_nv_test pci_epf_nv_test.0: BAR0 RAM IOVA: 0xe0000000
Hi ,
Could anyone help us?
Hi Wilson,
From RP → EP, you can access it via BAR address.
sudo lspci -vvv | grep region gives BAR address, use region 0 address to access the memory allocated on EP.
Hi Wayne,
Yes, I can get Region 0 address is 0x2428000000
RP:~$sudo lspci -vvv -s 0004:01:00.0 | grep Region
	Region 0: Memory at 2428000000 (32-bit, non-prefetchable) [size=64M]
	Region 2: Memory at 2140000000 (64-bit, prefetchable) [size=128K]
	Region 4: Memory at 242c000000 (64-bit, non-prefetchable) [size=4K]
RP:~$ sudo busybox devmem 0x2428000000
0x00000000
But It looks that can’t sync on EP:
EP:~$ sudo busybox devmem 0x2428000000
0xFFFFFFFF
Hi Wilson,
Address 0x2428000000 is valid on RP side only. On EP side, you must access the memory using the virtual address allocated by dma_alloc_coherent().
There is no way to access this memory using command line, please dump the memory in driver itself.
