I’m looking at the following code from NVIDIA that renders an image from a file descriptor called render_fd
EGLImageKHR hEglImage;
bool frame_is_late = false;
EGLSyncKHR egl_sync;
int iErr;
hEglImage = NvEGLImageFromFd(egl_display, render_fd);
if (!hEglImage)
COMP_ERROR_MSG("Could not get EglImage from fd. Not rendering");
return -1;
glActiveTexture(GL_TEXTURE0);
glBindTexture(GL_TEXTURE_EXTERNAL_OES, texture_id);
glEGLImageTargetTexture2DOES(GL_TEXTURE_EXTERNAL_OES, hEglImage);
glDrawArrays(GL_TRIANGLE_STRIP, 0, 4);
iErr = glGetError();
if (iErr != GL_NO_ERROR)
COMP_ERROR_MSG("glDrawArrays arrays failed:" << iErr);
return -1;
egl_sync = eglCreateSyncKHR(egl_display, EGL_SYNC_FENCE_KHR, NULL);
if (egl_sync == EGL_NO_SYNC_KHR)
COMP_ERROR_MSG("eglCreateSyncKHR() failed");
return -1;
eglSwapBuffers(egl_display, egl_surface);
if (eglGetError() != EGL_SUCCESS)
COMP_ERROR_MSG("Got Error in eglSwapBuffers " << eglGetError());
return -1;
if (eglClientWaitSyncKHR (egl_display, egl_sync,
EGL_SYNC_FLUSH_COMMANDS_BIT_KHR, EGL_FOREVER_KHR) == EGL_FALSE)
COMP_ERROR_MSG("eglClientWaitSyncKHR failed!");
if (eglDestroySyncKHR(egl_display, egl_sync) != EGL_TRUE)
COMP_ERROR_MSG("eglDestroySyncKHR failed!");
NvDestroyEGLImage(egl_display, hEglImage);
Here is the fragment shader:
#extension GL_OES_EGL_image_external : require
precision mediump float;
varying vec2 interp_tc;
uniform samplerExternalOES tex;
void main() {
gl_FragColor = texture2D(tex, interp_tc);
The problem is that I want to render independently from an display (or should I sar EGL display?). I might want to display it now but in the future I want to not use a display at all. I want to render to something and plug this something to another opengl program that renders it.
I found the documentation of NvEGLImageFromFd:
EGLImageKHR NvEGLImageFromFd(EGLDisplay display, int dmabuf_fd)
Creates an EGLImage instance from dmabuf-fd.
Parameters
[in] display EGLDisplay object used during the creation of EGLImage. If NULL, the nvbuf_utils API uses its own EGLDisplay instance.
[in] dmabuf_fd DMABUF FD of buffer from which EGLImage to be created.
It looks like I can pass NULL to it, so I tried the following code:
int iErr;
hEglImage = NvEGLImageFromFd(NULL, decodedNvFrame->nvBuffer->planes[0].fd);
if (!hEglImage)
printf("Could not get EglImage from fd. Not rendering\n");
glBindVertexArray(vertexArrayObject);
printf("glDrawArrays arrays failed:%i\n", iErr);
NvDestroyEGLImage(NULL, hEglImage);
Even though I see no errors, I also see no output in the screen. Is there something I’m missing? Are those eglConfig, eglSurfaces, etc, needed to render to a screen? If so, how to render to a buffer and then render to a screen?
