GPU (Ubuntu 20.04, 1080 GTX)
• DeepStream Version
6.1
N/A
• TensorRT Version
8.5.2-1+cuda11.8
515.65.01
Can’t link tee pads in C++
Attempt to link a pipeline including a tee using gst_element_request_pad(), gst_pad_link().
This seems like a trivial thing to accomplish, but my real issue is with finding the correct documentation. As stated above, I’ve been trying to use gst_element_request_pad() and gst_pad_link() to link a tee element to pads in respective forks. However, official gstreamer documentation moved on quite a bit ago from 1.16, which is the version deep stream has been developed with. Official gstreamer documentation gives examples to link pads between gstreamer elements at this link stating developers should use gst_element_request_pad_simple(). This function doesn’t seem to exist within deepstream, as it is part of gstreamer 1.20.
With this documentation conflict in mind, would someone be so kind as to spell out for me how to accomplish the following valid, working gstreamer pipeline string in C++?
gst-launch-1.0 -v v4l2src device=/dev/video2 ! video/x-h264,framerate=30/1,width=1920,height=1080 ! tee name=t t. ! queue ! h264parse ! nvv4l2decoder ! queue ! nveglglessink sync=0 t. ! queue ! rtph264pay pt=96 ! udpsink host=192.168.1.200 port=7331 sync=0
I can link and execute both forks of that tee individually in C++ no problem. Linking the tee to the second fork is when it dies, I get a black display screen and no UDP stream at the distant end. Curiously, I don’t see any errors thrown, though.
Here is the code linking relevant elements:
gst_bin_add_many(GST_BIN(data->bin), data->source, data->sourceFilter, data->tee, data->parse, data->decode, data->imageSink, data->payload, data->udpSink, NULL);
gst_element_link_many(data->source, data->sourceFilter, data->tee, NULL);
gst_element_link_many(data->parse, data->decode, data->imageSink, NULL);
gst_element_link_many(data->payload, data->udpSink, NULL);
gst_element_link(data->tee, data->parse);
gst_element_link(data->tee, data->payload);
It is when I try to link the tee that the pipeline breaks. i think this is because I’m not calling out specifically enough which pads should be connected between elements, but like I said I can’t figure it out just by reading documentation in this case.
Any help is appreciated, thanks in advance.
-Reed
