How to run customized YOLO V5 model on Nvidia Orin GPU cores
we downloaded basic Yolo v5 model from GitHub repo & r trying to run on GPU cores,
while running/selecting as device id using GPU, getting some errors
GPU not found, so how to run it on GPU?
how to run the YOLO-V5 model on GPU?
Please let me know the procedure to run the model on GPU…
Thanks in Advance,
L V GiriBabu.
Have you install the framework with CUDA supported?
For example, below is the link to install PyTorch with CUDA support:
https://docs.nvidia.com/deeplearning/frameworks/install-pytorch-jetson-platform/index.html
Thanks for ur reply,
Yes, our current framework supported the CUDA .
even we installed torch & torch vision packages also.
but while selecting device ID to GPU, model is throwing error " GPU not found "
we are thinking like GPU core will detect/active after install Pytorch with CUDA.
please correct me if I think wrong?
Thanks in advance,
How do you install the PyTorch?
Could you share the instructions with us?
