I went through DIGITS with DIGITS/GettingStarted.md at master · NVIDIA/DIGITS · GitHub and got LeNet. Could you let me know how to run LeNet on Jetson TX1? What kind of files are needed to be copied to Jetson TX1? How to test LeNet on Jetson TX1?
Thank you for the link. However, the link showed the Caffe-based solution. I found there is no Caffe on TX1 after installing JetPack. I’d like to run LeNet on TX1 like imagenet and detectnet using TensorRT because TensorRT looks much faster Caffe. Could you let me know how to run LeNet on TX1 like imagenet and detectnet? LeNet is trained using DIGITS.
