Is there any possible way to run the nvpmodel commands, and the jetson_clocks.sh script from within a running docker container?. This will help to control the device performance from within the container so that the running application, can make use of it.
Hi saikishor,
The nvpmode and jetson_clocks.sh are supported by default , not sure how to get them within the container for running application to control device performance, may other developers share experience if they have.
