Im currently able to run keras with tensorflow on webcam to achieve real-time detection
This is my code :
import keras
import pickle
#from videotest import VideoTest
import cv2
import numpy as np
import time
import sys
sys.path.append("/home/nvidia/yassd")
from keras.applications.imagenet_utils import preprocess_input
from keras.backend.tensorflow_backend import set_session
from keras.models import Model
from keras.preprocessing import image
import pickle
from rando
[code]
m import shuffle
#from scipy.misc import imread, imresize
from timeit import default_timer as timer
import sys
sys.path.append(“..”)
from ssd_utils import BBoxUtility
from ssd import SSD300 as SSD
input_shape = (300, 300, 3)
conf_thresh = 0.6
Change this if you run with other classes than VOC
class_names = [“background”, “aeroplane”, “bicycle”, “bird”, “boat”, “bottle”, “bus”, “car”, “cat”, “chair”, “cow”,
“diningtable”, “dog”, “horse”, “motorbike”, “person”, “pottedplant”, “sheep”, “sofa”, “train”,
“tvmonitor”];
NUM_CLASSES = len(class_names)
model = SSD(input_shape, num_classes=NUM_CLASSES)
Change this path if you want to use your own trained weights
model.load_weights(‘/home/nvidia/yassd/weights_SSD300.hdf5’)
cap = cv2.VideoCapture(1)
bbox_util = BBoxUtility(NUM_CLASSES)
class_colors =
for i in range(0, NUM_CLASSES):
# This can probably be written in a more elegant manner
hue = 255 * i / NUM_CLASSES
col = np.zeros((1, 1, 3)).astype(“uint8”)
col[0][0][0] = hue
col[0][0][1] = 128 # Saturation
col[0][0][2] = 255 # Value
cvcol = cv2.cvtColor(col, cv2.COLOR_HSV2BGR)
col = (int(cvcol[0][0][0]), int(cvcol[0][0][1]), int(cvcol[0][0][2]))
class_colors.append(col)
ret, img = cap.read()
Compute aspect ratio of image
imgh, imgw, channels = img.shape
imgar = imgw / imgh
im_size = (input_shape[0], input_shape[1])
while(True):
# Capture frame-by-frame
resized = cv2.resize(img, im_size)
rgb = cv2.cvtColor(resized, cv2.COLOR_BGR2RGB)
to_draw = cv2.resize(resized, (int(input_shape[0] * imgar)*3, input_shape[1]*3))
# Use model to predict
inputs = [image.img_to_array(rgb)]
tmp_inp = np.array(inputs)
x = preprocess_input(tmp_inp)
st = time.time()
y = model.predict(x)
print('Elapsed time = {}'.format(time.time() - st))
results = bbox_util.detection_out(y)
if len(results) > 0 and len(results[0]) > 0:
# Interpret output, only one frame is used
det_label = results[0][:, 0]
det_conf = results[0][:, 1]
det_xmin = results[0][:, 2]
det_ymin = results[0][:, 3]
det_xmax = results[0][:, 4]
det_ymax = results[0][:, 5]
top_indices = [i for i, conf in enumerate(det_conf) if conf >= conf_thresh]
top_conf = det_conf[top_indices]
top_label_indices = det_label[top_indices].tolist()
top_xmin = det_xmin[top_indices]
top_ymin = det_ymin[top_indices]
top_xmax = det_xmax[top_indices]
top_ymax = det_ymax[top_indices]
for i in range(top_conf.shape[0]):
xmin = int(round(top_xmin[i] * to_draw.shape[1]))
ymin = int(round(top_ymin[i] * to_draw.shape[0]))
xmax = int(round(top_xmax[i] * to_draw.shape[1]))
ymax = int(round(top_ymax[i] * to_draw.shape[0]))
# Draw the box on top of the to_draw image
class_num = int(top_label_indices[i])
cv2.rectangle(to_draw, (xmin, ymin), (xmax, ymax),
class_colors[class_num], 2)
text = class_names[class_num] + " " + ('%.2f' % top_conf[i])
text_top = (xmin, ymin - 10)
text_bot = (xmin + 80, ymin + 5)
text_pos = (xmin + 5, ymin)
cv2.rectangle(to_draw, text_top, text_bot, class_colors[class_num], -1)
cv2.putText(to_draw, text, text_pos, cv2.FONT_HERSHEY_SIMPLEX, 0.35, (0, 0, 0), 1)
# Display the resulting frame
cv2.imshow("detection", to_draw)
if cv2.waitKey(1) & 0xFF == ord('q'):
break
When everything done, release the capture
cap.release()
cv2.destroyAllWindows()[/code]
