I am trying to leverage GPU support for Tensorflow on my Quadro 1200 GPU on Windows.
I am following this guide:
* NVIDIA GPU Accelerated Computing on WSL 2
Following this guide, I land up with the following error when I run tf.config.list_physical_devices('GPU')
2023-06-15 11:21:53.600227: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:982] could not open file to read NUMA node: /sys/bus/pci/devices/0000:01:00.0/numa_node
Your kernel may have been built without NUMA support.
2023-06-15 11:21:53.936656: W tensorflow/core/common_runtime/gpu/gpu_device.cc:1956] Cannot dlopen some GPU libraries. Please make sure the missing libraries mentioned above are installed properly if you would like to use GPU. Follow the guide at https://www.tensorflow.org/install/gpu for how to download and setup the required libraries for your platform.
Skipping registering GPU devices...
How can I run Tensorflow with my Quadro 1200 GPU?
As per the guide, I opted for Option 1: Installation of Linux x86 CUDA Toolkit using WSL-Ubuntu Package.
After completing all the steps in the guide, I followed the following installation commands as per Tensorflow installation page for Windows WSL2:
conda install -c conda-forge cudatoolkit=11.8.0
python3 -m pip install nvidia-cudnn-cu11==8.6.0.163 tensorflow==2.12.*
mkdir -p $CONDA_PREFIX/etc/conda/activate.d
echo 'CUDNN_PATH=$(dirname $(python -c "import nvidia.cudnn;print(nvidia.cudnn.__file__)"))' >> $CONDA_PREFIX/etc/conda/activate.d/env_vars.sh
echo 'export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$CONDA_PREFIX/lib/:$CUDNN_PATH/lib' >> $CONDA_PREFIX/etc/conda/activate.d/env_vars.sh
source $CONDA_PREFIX/etc/conda/activate.d/env_vars.sh
# Verify install:
python3 -c "import tensorflow as tf; print(tf.config.list_physical_devices('GPU'))"
When I execute the last command, I get the following errors:
(condaenv) root@DESKTOP-CHV5AM:/home/admin/Python# python3 -c "import tensorflow as tf; print(tf.config.list_physical_devices('GPU'))"
2023-06-15 12:52:11.886160: I tensorflow/core/platform/cpu_feature_guard.cc:182] This TensorFlow binary is optimized to use available CPU instructions in performance-critical operations.
To enable the following instructions: AVX2 FMA, in other operations, rebuild TensorFlow with the appropriate compiler flags.
2023-06-15 12:52:12.493026: W tensorflow/compiler/tf2tensorrt/utils/py_utils.cc:38] TF-TRT Warning: Could not find TensorRT
2023-06-15 12:52:13.151393: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:982] could not open file to read NUMA node: /sys/bus/pci/devices/0000:01:00.0/numa_node
2023-06-15 12:52:13.174058: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:982] could not open file to read NUMA node: /sys/bus/pci/devices/0000:01:00.0/numa_node
2023-06-15 12:52:13.174904: I tensorflow/compiler/xla/stream_executor/cuda/cuda_gpu_executor.cc:982] could not open file to read NUMA node: /sys/bus/pci/devices/0000:01:00.0/numa_node
[PhysicalDevice(name='/physical_device:GPU:0', device_type='GPU')]
