how to run two __global__ funtions simultaneously in two CUDA devices
Hi,all.
i’m new in CUDA programming. As i have two GTX560 cards, i want to know how to run two global funtions simultaneously in two desktop GeForce CUDA-suppoted cards respectively,
or can i run these global functions sequentially in one card ?
thanks,
best regards
You may try something like that
// Select the device 0 as the curent device
cudaSetDevice(0);
Kernel1<<<gridSize,blockSize>>>();
/* Other action on device 0 */
// Select the device 1 as the curent device
cudaSetDevice(1);
Kernel2<<<gridSize,blockSize>>>();
/* Other action on device 1 */
And don’t forget to check all return values of cuda functions call
thanks a lot~
and by the way do you know how to copy data from one array to another within a device and global function(it’s not like those copying jobs between host and device)?
You can use memcpy like in a “normal” C program if you program in C. If you use another langage use the same function that if you were not in Cuda.
