Hi, I am using NX on a robocar project, as you can see here https://pbs.twimg.com/media/FRDkcOlUUAA_N-c?format=jpg&name=large To reduce the car body height, I put the Nx dev kit up-side down under the car deck. The GPIO pins on NX dev kit now point downward. I use breadboard jumper wires to connect my IMU and Segment LED to Nx dev kit GPIO. Since the GPIO pins point downward, the wire is very easy to get loose. How can I secure the wire? I do not want to solder because that will permanently impact the NX GPIO pins.
Hope someone has such experience can be shared. NV don’t have suggestion on this.
