I have two nvidia devices(quadro M2000) in PC.
How to select nvidia device in which I want to run NPP library in codes?
Now,Npp library is executed only first nvida device.
try using cudaSetDevice()
| Is the npp lib only for host ? | 1 | 567 | November 23, 2018 | |
| NPPI v7.5 can not run on GTX1070 card | 0 | 539 | December 13, 2016 | |
| Two cards on the same cluster | 2 | 3343 | April 23, 2008 | |
| how to select the device manually | 2 | 4324 | November 4, 2009 | |
| Running NPP library with CUDA | 6 | 17907 | August 1, 2010 | |
| Question about multi-GPU support mentioned in the NPP Plus introduction | 0 | 67 | August 8, 2024 | |
| [bug] Current device change after nppsMalloc(); does nppsMalloc() call cudaSetDevice()? | 3 | 124 | April 10, 2025 | |
| NPP 1.0 available | 3 | 11383 | March 29, 2016 | |
| CUDA on notebook | 6 | 1093 | May 25, 2016 | |
| NPP functions failure with multiple devices | 2 | 1103 | February 27, 2023 |
