On NVIDIA Performance Primitives (NPP) | NVIDIA Developer. The “Download NPP +” section mentions that the “NPP + library, … , plus the added advantage of multi-GPU support.” Does the term “multi-GPU support” in this context refer to a specific operator in NPP+ that enables multiple GPU devices to work together to compute the current operator by setting the nCudaDeviceId parameter (or other parameters) of NppStreamContext? If so, can you provide a specific example? If not, what is the meaning of “multi-GPU support”? Thanks.
Related topics
| Should I be using nppplus instead of npp? | 1 | 163 | April 23, 2025 | |
| NPP | 0 | 864 | November 12, 2013 | |
| How many programmers use Nvidia NPP | 7 | 3559 | May 31, 2011 | |
| npp and parallelism | 2 | 669 | October 18, 2021 | |
| NPP 1.0 available | 3 | 11381 | March 29, 2016 | |
| NPP & stream problems? | 1 | 1727 | October 12, 2021 | |
| Is the npp lib only for host ? | 1 | 565 | November 23, 2018 | |
| NPP Stream crash | 5 | 2577 | March 21, 2017 | |
| NPP vs VPI | 1 | 1384 | September 23, 2021 | |
| Running NPP library with CUDA | 6 | 17895 | August 1, 2010 |
