Hi NVs,
I am doing some test which send video by rtsp in jetson nano, and I have achieved it by udp connect just like below.
#!/usr/bin/env python
import cv2
import gi
gi.require_version('Gst', '1.0')
gi.require_version('GstRtspServer', '1.0')
from gi.repository import GObject, Gst, GstRtspServer
def main():
# jetson 平台
out_send = cv2.VideoWriter('appsrc is-live=true ! videoconvert ! \
omxh264enc bitrate=12000000 ! video/x-h264, \
stream-format=byte-stream ! rtph264pay pt=96 ! \
udpsink host=127.0.0.1 port=5400 async=false',
cv2.CAP_GSTREAMER, 0, 30, (1920,1080), True)
if not out_send.isOpened():
print('VideoWriter not opened')
exit(0)
rtsp_port_num = 8554
server = GstRtspServer.RTSPServer.new()
server.props.service = "%d" % rtsp_port_num
server.attach(None)
factory = GstRtspServer.RTSPMediaFactory.new()
factory.set_launch("(udpsrc name=pay0 port=5400 buffer-size=524288 \
caps=\"application/x-rtp, media=video, clock-rate=90000, \
encoding-name=(string)H264, payload=96 \")")
factory.set_shared(True)
server.get_mount_points().add_factory("/ds-test", factory)
# 输出rtsp码流信息
print("\n *** Launched RTSP Streaming at rtsp://localhost:%d/ds-test ***\n\n" % rtsp_port_num)
cap = cv2.VideoCapture("rtsp://admin:jiaxun123@192.168.170.65:554")
while True:
_, mat = cap.read()
out_send.write(mat)
cv2.waitKey(30)
if __name__ == '__main__':
main()
But I want to achieve it by TCP connect rather than udpsink and udpsrc. I know the useful elements are tcpserversink and tcpclient, but I can’t make the correct pipelient. So can you help me? Thanks!
