Gstreamer TCPserversink 2-3 seconds latency
I’m trying to send a video stream with tcp, but I get 2-3 seconds of latency, and i’m looking to reduce it as much as possible. The received stream sometimes stop on a gray image and then receive a burst of frames in accelerate.
We have a Jetson NX Xavier devkit on Jetpack 4.5.1. I’m using it with nvpmodel -m 2 and jetson_clocks --fan.
I enabled VIC to run in max clock as described here
Command v4l2-ctl --list-formats-ext -d /dev/video0 give :
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘YUYV’
Size: Discrete 1920x1080
Interval: Discrete 0.017s (60.000 fps)
Here is my pipeline :
> std::string gst_out = "appsrc ! videoconvert ! queue ! nvvidconv ! nvv4l2h265enc maxperf-enable=1 ! h265parse ! matroskamux ! tcpserversink port=AAAA host=XXX.XXX.XXX.XXX sync=false async=false";
And my codec :
cv::VideoWriter out(gst_out, cv::VideoWriter::fourcc('F', 'M', 'P', '4'), double(fps), cv::Size(int(w), int(h)));
I tried to remove videoconvert with video/x-raw, format=YUYV, width=1920, height=1080, framerate=60/1, but it doesn’t work with this setup.
Videostream check with fpsdisplaysink
gst-launch-1.0 v4l2src ! videoconvert ! fpsdisplaysink text-overlay=0 video-sink=fakesink sink=0 -v
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0: sync = true
Setting pipeline to PLAYING …
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)60/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)60/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)60/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)60/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)60/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)60/1, format=(string)YUY2, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)bt709, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 32, dropped: 0, current: 61,95, average: 61,95
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 63, dropped: 0, current: 60,01, average: 60,98
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 93, dropped: 0, current: 60,00, average: 60,66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 124, dropped: 0, current: 60,00, average: 60,49
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 154, dropped: 0, current: 60,00, average: 60,40
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 185, dropped: 0, current: 60,00, average: 60,33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 216, dropped: 0, current: 60,01, average: 60,28
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 247, dropped: 0, current: 59,99, average: 60,25
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 278, dropped: 0, current: 60,00, average: 60,22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 309, dropped: 0, current: 60,00, average: 60,20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 339, dropped: 0, current: 60,00, average: 60,18
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 370, dropped: 0, current: 60,00, average: 60,16
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 401, dropped: 0, current: 60,00, average: 60,15
^Chandling interrupt.
Interrupt: Stopping pipeline …
Execution ended after 0:00:07.000306499
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
Thank you !
Please adjust the two properties in nvv4l2h265enc and try:
  iframeinterval      : Encoding Intra Frame occurance frequency
                        flags: readable, writable, changeable only in NULL or READY state
                        Unsigned Integer. Range: 0 - 4294967295 Default: 30
  idrinterval         : Encoding IDR Frame occurance frequency
                        Unsigned Integer. Range: 0 - 4294967295 Default: 256
The default setting may not be good for streaming, may try idrinterval=30 or15.
Hi DaneLLL,
I tried multiples value for idrinterval (15, 30) and iframeinterval (5, 10, 20, 50, 100, 200, 300, 600), but nothing changed.
Here is my code :
gstreamer_tcp.cpp (2.7 KB)
Where can I see the documentation about all the Gstreamer nvidia properties like idrinterval ? I can’t find them in the ACCELERATED GSTREAMER USER GUIDE ?
Here is a sample of what I am getting :
Don’t you think it can also come from the videoconvert plug-in ?
Are you able to try UDP streaming? We have tried UDP in TX2 NX as server and x86 PC as client.
Server command:
$ gst-launch-1.0 videotestsrc is-live=1 ! video/x-raw,width=1280,height=720 ! timeoverlay valignment=4 halignment=1 ! nvvidconv ! 'video/x-raw(memory:NVMM),width=1280,height=720' ! tee name=t ! nvv4l2h264enc insert-sps-pps=1 idrinterval=15 ! h264parse ! rtph264pay ! udpsink host=10.19.106.10 port=5000 sync=0 t. ! queue ! nvegltransform ! nveglglessink sync=0
Client command:
$ gst-launch-1.0 udpsrc port=5000 ! 'application/x-rtp,encoding-name=H264,payload=96' ! rtph264depay ! avdec_h264 ! xvimagesink sync=0
The result(left is TX2 NX and right is x86 PC):
Could you try server commands in the cases:
  1. gst-launch-1.0 videotestsrc in UDP
  2. gst-launch-1.0 videotestsrc in TCP
  3. gst-launch-1.0 OpenCV in UDP
See if we can clarify where the latency is from by trying these cases.
And please run gst-inspect-1.0 nvv4l2h265enc to get all properties.
Hi DaneLLL,
I am not able to stream UDP with these commands, I get the same screen as you when i’m streaming from the NX Xavier, but my Ubuntu 18.04 x86 PC doesn’t get the videotest :
Définition du pipeline à PAUSED...
Le pipeline est actif et n’a pas besoin de phase PREROLL…
Passage du pipeline à la phase PLAYING…
Interruption : arrêt du pipeline…
Execution ended after 0:00:17.859331593
Définition du pipeline à READY (prêt)…
Définition du pipeline à NULL…
Libération du pipeline…
And no image is shown.
Also gst-launch-1.0 nvv4l2h265enc give me this on my NX Xavier :
$ gst-launch-1.0 nvv4l2h265enc
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
Interrupt: Stopping pipeline ...
Execution ended after 0:00:07.792176179
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
The command was not correct and I have fixed it. It should be gst-inspect-1.0.
For streaming to your host PC, do you change host=10.19.106.10 to IP address of the host PC?
Hi DaneLLL, thanks for fast reply,
It should be gst-inspect-1.0 .
It works, thanks.
    It works great, I have like 20ms latency.
    Please, correct me if i’m wrong : I have to specify the IP address of my NX, do I use tcpclientsrc or tcpserversrc :
gst-launch-1.0 tcpserversrc host=NX.Address.IP port=5000 ! 'application/x-rtp,encoding-name=H264,payload=96' ! rtph264depay ! avdec_h264 ! xvimagesink sync=0
I don’t receive image with this.
Transmitter pipeline (NX) :
gst-launch-1.0 videotestsrc is-live=1 ! video/x-raw,width=1280,height=720 ! timeoverlay valignment=4 halignment=1 ! nvvidconv ! 'video/x-raw(memory:NVMM),width=1280,height=720' ! tee name=t ! nvv4l2h264enc insert-sps-pps=1 idrinterval=15 ! h264parse ! rtph264pay ! tcpserversink host=NX.Address.IP port=5000 sync=0 t. ! queue ! nvegltransform ! nveglglessink sync=0
  1. gst-launch-1.0 OpenCV in UDP
std::string gst_out = "appsrc ! video/x-raw,width=1920,height=1080 ! videoconvert ! timeoverlay valignment=4 halignment=1 ! nvvidconv ! 'video/x-raw(memory:NVMM),width=1920,height=1080' ! tee name=t ! nvv4l2h264enc insert-sps-pps=1 idrinterval=15 ! h264parse ! rtph264pay ! udpsink host=PC.Address.IP port=5000 sync=0 t. ! queue ! nvegltransform ! nveglglessink sync=0
It works with 0-20ms latency (calculated with a few photo) notice the videoconvert, otherwise it wouldn’t push frame to the pipeline.
I also get some frame all blurred, it doesn’t happen too often thought, it can come from so much things, do you have any idea about this ?
So, it appears that the latency came from tcpserversink.
Thank you so much DaneLLL !
Now that the transmission is working really well, (I also changed the encoder from 264 to 265 and the quality is much higher). I can’t receive my stream with VLC using udp://@NX.Address.IP:PORT .
It seems that I need to define the packet size, but I can’t find which parameters can do it. Can you tell me if this is the correct way to read the stream with VLC, or is there a simpler way ?
Update : I managed to stream my video with UDP with Gstreamer on an application to VLC with a .sdp file, but I now have 500ms of latency, i use the same pipeline as before :
std::string gst_out = "appsrc ! video/x-raw,width=1920,height=1080 ! videoconvert ! timeoverlay valignment=4 halignment=1 ! nvvidconv ! video/x-raw(memory:NVMM),width=1920,height=1080 ! tee name=t ! nvv4l2h265enc insert-sps-pps=1 idrinterval=15 ! h265parse ! rtph265pay ! udpsink host=PC.Address.IP port=5000 sync=0 t. ! queue ! nvegltransform ! nveglglessink sync=0
and my .sdp file :
v=0
m=video #PORT RTP/AVP 96
c=IN IP4 192.168.1.21
a=rtpmap:96 H265/90000
Can I reduce this latency ?
Not sure but it seems like there is buffering mechanism in VLC. This would need other users to share experience.
It may help to run in CBR + setting virtual buffer size. It avoid burst bitrate between I and P frames and may offer better stability in limited network bandwidth. Please check the example of setting it:
Random blockiness in the picture RTSP server-client -Jetson TX2 - #5 by DaneLLL
Hi DaneLLL,
Thanks for advices,
Indeed, it looks like it, I could see some blurred frame regularly when I put previous pipeline into VLC. It gets corrected by adjusting the bitrate and setting the vbv-size as you told.
Now that I can use UDP, I now have 1-2 seconds latency with this pipeline :
std::string gst_out = "appsrc ! video/x-raw,width=1920,height=1080 ! videoconvert ! timeoverlay valignment=4 halignment=1 ! nvvidconv ! video/x-raw(memory:NVMM),width=1920,height=1080 ! tee name=t ! nvv4l2h265enc EnableTwopassCBR=1 insert-sps-pps=1 idrinterval=2 bitrate=64000000 vbv-size=1600000 maxperf-enable=1 ! h265parse ! rtph265pay config-interval=1 pt=96 ! udpsink host=PC.Address.IP port=PORT sync=0 async=0  t. ! nvegltransform ! nveglglessink max-lateness=11000 sync=0";
Tried to remove these parameters : max-lateness=11000, EnableTwopassCBR=1, insert-sps-pps=1, idrinterval=2, it doesn’t seems to affect anything to the stream.
I didn’t use VLC in my solution, we receive the stream with the Windows Gstreamer library and I have something like 30ms latency with udpsink.
Here is a pipeline that works for me if someone wants to send it to VLC, but I couldn’t get better than 1s latency :
std::string gst_out = "appsrc is-live=1 ! video/x-raw, width=1920, height=1080 ! videoconvert ! timeoverlay valignment=4 halignment=1 ! nvvidconv ! video/x-raw(memory:NVMM), width=1920, height=1080 ! tee name=t ! nvv4l2h265enc EnableTwopassCBR=1 insert-sps-pps=1 idrinterval=15 iframeinterval=1000 bitrate=64000000 vbv-size=1600000 maxperf-enable=1 preset-level=1 ! h265parse ! rtph265pay config-interval=1 pt=96 ! udpsink host=IP.address port=PORTsync=0 async=0 t. ! nvegltransform ! nveglglessink max-lateness=11000 sync=0";
The receiver needs to open a .sdp file to read that stream. Adjusting the bitrate helps suppressing blurred frame.
Thank you DaneLLL for the help.
