For 4K video playback, please do
- Execute sudo nvpmodel -m 0 and sudo jetson_clocks
- Refer to the post to run VIC engine at maximum clock:
EGLstream DMA Consumer solutions
And see if there is improvement. Furthermore, you may construct the pipeline manually so that enable-max-performance can be enabled in nvv4l2decoder plugin.
The source looks to be a UDP source and you can refer to the pipelines:
Gstreamer TCPserversink 2-3 seconds latency - #5 by DaneLLL
Nvv4l2decoder sometimes fails to negotiate with downstream after several pipeline re-launches - #16 by DaneLLL
