hello,
I use pipeline :
mainLoop_ = g_main_loop_new(NULL, FALSE);
sourcePipeline_ = gst_pipeline_new(“rtsp-decode-pipeline”);
source_ = gst_element_factory_make(“uridecodebin”, “uri-decode”);
videoconvert_ = gst_element_factory_make(“videoconvert”, “videoconvert”);
appsink_ = gst_element_factory_make(“appsink”, “rtsp-appsink”);
I get result surface correctly , but surface memory layout is NVBUF_LAYOUT_BLOCK_LINEAR, anybdoy know how to set to
NVBUF_LAYOUT_PITCH. Because NVBUF_LAYOUT_BLOCK_LINEAR can not process with opencv, I must NvBufSurfTransform change layout?
• Hardware Platform (Jetson )
• DeepStream Version(6.0)
• JetPack Version (4.6)
• TensorRT Version
• TensorRT Version
This sample i already test, it’s ok when layout is pitch, but output result layout is linear, opencv save result is not right jpg. So I create surface to NvBufSurfTransform convert to pitch, then save is right. My question is how to set param that I could get suface layout is pitch not linear? or unsupport set?
