How to set the dbscan_min_samples parameter in facenet notebook
I’m trying to run facenet, a sample notebook from the TAO toolkit provided by NVIDIA, and I got an error message.
It was caused by a value that could not be converted to an integer being entered into int(). I found that the value of descan_min_samples in $SPECS_DIR/facenet_train_resnet18_kitti.txt was 0.03.
When I changed this value to 3 as a trial, I got an error message telling me to set it to 1 or less.
I thought it might be a variable to set the percentage of the total number of samples, but if I set it to a value less than 1, the code would not run in the first place.
What is the correct way to set this variable?
Good morning,
I had the same issue tring to convert PeopleNet etlt model to tensorRT engine in TAO 5 and using the spec file available withing the last version of nvidia-tao repository
Are the spec file changed from TAO 4 to TAO 5?
Yes, please set to 1.
Refer to https://github.com/NVIDIA/tao_tutorials/blob/b7ea82a06f1b866018947f73185b5f48abe5a693/notebooks/tao_launcher_starter_kit/detectnet_v2/specs/detectnet_v2_train_resnet18_kitti.txt#L74
