How to setup the Orin WakeOnlan function in the other lan controller(the same with RTL8111H)
Hi Nvidia,
We have two lan port (use the same lan controller RTL8111H) in jetson orin platform(carrier board is design by us),and want to check the WakeOnlan function.
We found the Orin module’s WOL function is correct,but the other lan controller can’t work.
is any items need to be modified ?
BR
Warren
The other network card is not part of what we can directly suggest because they are from other vendor or maybe other cards/drivers.
You may check with Realtek whether those cards can support WoL first. If they can, then check whether the PCIe wake is enabled in kernel/kernel-5.10/drivers/soc/tegra/pmc.c
What we can help is the functionality of the on-board ethernet.
Tks,
We contact with ic vendor and solve this
