How to setup VC++2005 forCUDA the program compiled but the linker not cooperating :)
hi,
I had followed an excellent tutorial on setting up VC++2005 Express to run CUDA code, however it worked till the compile part, the Linker keeps saying that Cudart.lib and Cuda32.lib files aremissing. please help me with that one.
[url=“My first CUDA program! | /// Parallel Panorama ///”]http://llpanorama.wordpress.com/2008/05/21...t-cuda-program/[/url]
It gave me a linker error
LINK : fatal error LNK1181: cannot open input file ‘cudart.lib’
you just set
[codebox]Configuration Properties → Linker → Input:
Additional Dependencies = cudart.lib cutil32.lib[/codebox]
you should use absolute path such as
C:\CUDA\lib64\cudart.lib
or specified PATH for linking, say
Additional library directories = C:\CUDA\lib64
above is for 64-bit, for 32-bit, use C:\CUDA\lib instead.
as for cutil32.lib, it locates at
C:\Documents and Settings\All Users\Application Data\NVIDIA Corporation\NVIDIA CUDA SDK\C\common\lib
(for cuda 2.3)
so you can use absolute path
C:\Documents and Settings\All Users\Application Data\NVIDIA Corporation\NVIDIA CUDA SDK\C\common\lib\cutil64.lib
(fro 64-bit)
finally, check your environment variable "PATH’, which should contains
C:\CUDA\bin64 (64-bit) or
C:\CUDA\bin (32-bit) and
or program cannot find DLL support
I’m using CUDA 2.2, my card does not support the CUDA 2.3 driver. its a GeForce 8600, i think 4 SM , 32 SP. type CUDA enabled.
I just made an attachment of my log file,
I was able to locate cudart.lib and cutil32D.lib in the following folders respectively.
C:\CUDA\lib\cudart.lib
C:\ProgramData\NVIDIA Corporation\NVIDIA CUDA SDK\Common\lib\cutil32D.lib
i log into my windows vista after entering the username and password though i am the administrator, does that kind of logging in affect the path.
BuildLog.htm (4.59 KB)
I did the following and it compiled just fine.
Tools ->options
in the options window
select
Project and Solutions
choose
VC++ Directories
click on new line icon
manually locate and add cudart.lib and cutil32.lib.
Once those paths are included
The program builds and runs just fine
