How to solve a 3D time-dependent aneurysm problem in Modulus Sym
surface mesh simulation results is .vtp files at different time.
Known geometry files:closed.stl, inlet.stl, noslip.stl, outlet.stl.
I can manually build a dictionary of input and output variables that reflect the different discrete points in time.
But, how to select the interior points that reflect the different discrete points in time for ‘PointwiseInteriorConstraint’?
How to solve this 3D time-dependent aneurysm problem in Modulus Sym?
Can you please give any suggestions on this? Thanks.
