Hi there, I have been working with CUDA for quite a long now and have implemented quite a few programs. But for the first time, I am facing a difficulty with an error called “Fatal error. Memory allocation cannot be possible”. I have searched in the internet and couldn’t find any satisfactory solution. Here I would like to mention that I am using CUDA 6 version, Linux 64 bit operating system with 64 GB Ram support and 2TB hard disk support. I have checked memory status and it shows only 3% is in use. I have used CUDAMalloc function to allocate memory. But still this problem arises. So, anybody if could help me out in this regard will be very much helpful. Thanks in advance.
Related topics
| How to solve memory allocation problem in cuda?? | 4 | 31353 | February 2, 2015 | |
| cudaErrorMemoryAllocation just after CUDA installation | 0 | 1480 | May 12, 2021 | |
| cudaMalloc fails on huge allocation | 4 | 861 | March 28, 2011 | |
| CUDA problema | 4 | 4785 | April 15, 2010 | |
| Memory Limit in Emulation Mode | 1 | 1851 | October 22, 2007 | |
| cudamalloc not allocating memeory | 0 | 1306 | May 1, 2012 | |
| cudaMalloc failing cuda malloc failing | 0 | 2026 | August 8, 2011 | |
| How to solve memory allocation problem in cuda?? | 1 | 4323 | September 25, 2015 | |
| bug in memory allocation? | 6 | 4230 | May 24, 2012 | |
| cudaMalloc() is returning cudaErrorMemoryAllocation. what could be the reasons? | 5 | 13224 | August 13, 2009 |
