I am currently experimenting with lula kinematics and was wondering if it is possible to change the robot configuration that is resulting from the inverse kinematics in lula.
Industrial robots can reach the same position with different robot configurations. Some configurations may lead to collisions between the robot and its environment, as seen in this example:
Is there an option to choose the robot configuration, for example through a seed that is passed to the controller?
If you know a “near solution”, you can pass this is in as a warm start.
Another option is to solve IK multiple times using a broad sample of seeds in order to identify multiple solutions. In this case, you could take all the solutions from each run, identify the unique options and pick the one that is best for your application.
