So I fix some problem in my code, including:
- stop doing inplace
shfl, since it would override value that other wraplane want to read
- do
__wrapsync() to make sure register is actually written before shfl
Here’s the full code compiled and benchmarked with 4090 / cc8.9.
#include <cuda_fp16.h>
template<int MODE>
__device__ __forceinline__ void shf(int (&i)[4], int (&o)[4]) {
__syncwarp();
int y = threadIdx.y % 4;
*(int4*)o = *(int4*)i;
switch (MODE) {
case 0:
asm("{.reg .pred %p;"
"setp.ne.s32 %p,%8,0;"
"@%p bra L1;"
"shfl.sync.bfly.b32 %1,%4,1,31,-1;"
"shfl.sync.bfly.b32 %2,%4,2,31,-1;"
"shfl.sync.bfly.b32 %3,%4,3,31,-1;"
"bra L0;"
"L1:"
"setp.ne.s32 %p,%8,1;"
"@%p bra L2;"
"shfl.sync.bfly.b32 %0,%5,1,31,-1;"
"shfl.sync.bfly.b32 %3,%5,2,31,-1;"
"shfl.sync.bfly.b32 %2,%5,3,31,-1;"
"bra L0;"
"L2:"
"setp.ne.s32 %p,%8,2;"
"@%p bra L3;"
"shfl.sync.bfly.b32 %3,%6,1,31,-1;"
"shfl.sync.bfly.b32 %0,%6,2,31,-1;"
"shfl.sync.bfly.b32 %1,%6,3,31,-1;"
"bra L0;"
"L3:"
"shfl.sync.bfly.b32 %2,%7,1,31,-1;"
"shfl.sync.bfly.b32 %1,%7,2,31,-1;"
"shfl.sync.bfly.b32 %0,%7,3,31,-1;"
"L0:}"
:"=r"(o[0]), "=r"(o[1]), "=r"(o[2]), "=r"(o[3])
:"r"(i[0]), "r"(i[1]), "r"(i[2]), "r"(i[3]), "r"(y));
break;
case 1:
switch (y) {
case 0:
o[1] = __shfl_xor_sync(0xffffffff, i[0], 1);
o[2] = __shfl_xor_sync(0xffffffff, i[0], 2);
o[3] = __shfl_xor_sync(0xffffffff, i[0], 3);
break;
case 1:
o[0] = __shfl_xor_sync(0xffffffff, i[1], 1);
o[3] = __shfl_xor_sync(0xffffffff, i[1], 2);
o[2] = __shfl_xor_sync(0xffffffff, i[1], 3);
break;
case 2:
o[3] = __shfl_xor_sync(0xffffffff, i[2], 1);
o[0] = __shfl_xor_sync(0xffffffff, i[2], 2);
o[1] = __shfl_xor_sync(0xffffffff, i[2], 3);
break;
default:
o[2] = __shfl_xor_sync(0xffffffff, i[3], 1);
o[1] = __shfl_xor_sync(0xffffffff, i[3], 2);
o[0] = __shfl_xor_sync(0xffffffff, i[3], 3);
break;
case 2:
if (y == 0) {
} else if (y == 1) {
} else if (y == 2) {
} else {
break;
default:
for (int x = 0; x < 4; x++) {
if (x == y) {
for (int j = 1; j < 4; j++) {
o[x ^ j] = __shfl_xor_sync(0xffffffff, i[x], j);
break;
template<int MODE>
struct e2828 {
// (2x8)x(2x8) matrix where each wraplane hold 4x2 in (2x2)x(row major 8x8);
int _[4];
__device__ __forceinline__ void ld(const half* __restrict__ A, int Y) {
int _[4];
*(int4*)_ = ((int4*)A)[(threadIdx.y << 3 & 16 | threadIdx.y >> 1 & 14) * Y | threadIdx.y & 1];
shf<MODE>(_, this->_);
__device__ __forceinline__ void st(half* __restrict__ A, int Y) {
int _[4];
shf<MODE>(this->_, _);
((int4*)A)[(threadIdx.y << 3 & 16 | threadIdx.y >> 1 & 14) * Y | threadIdx.y & 1] = *(int4*)_;
__device__ __forceinline__ void zero() {
((long*)_)[0] = 0;
((long*)_)[1] = 0;
__device__ __forceinline__ void mm(e2828 a, e2828 b) {
asm("mma.sync.aligned.m16n8k16.row.col.f16.f16.f16.f16 {%0,%2},{%4,%5,%6,%7},{%8,%9},{%0,%2};"
"mma.sync.aligned.m16n8k16.row.col.f16.f16.f16.f16 {%1,%3},{%4,%5,%6,%7},{%10,%11},{%1,%3};":
"=r"(_[0]), "=r"(_[1]), "=r"(_[2]), "=r"(_[3]):
"r"(a._[0]), "r"(a._[1]), "r"(a._[2]), "r"(a._[3]),
"r"(b._[0]), "r"(b._[1]), "r"(b._[2]), "r"(b._[3]));
template<int MODE, int X, int Y, int Z>
__global__ void ker(const half * __restrict__ A, const half * __restrict__ B, half * __restrict__ O) {
e2828<MODE> a, b, o;
for (int x = 0; x < X; x++) {
for (int y = 0; y < Y; y++) {
o.zero();
for (int z = 0; z < Z; z++) {
a.ld(A + (x * 16 * Z + z) * 16, Z);
b.ld(B + (y * 16 * Z + z) * 16, Z);
o.mm(a, b);
o.st(O + (x * 16 * Y + y) * 16, Y);
int main() {
half *A, *B, *O;
cudaMalloc(&A, 64 * 16 * 64 * 16 * 2);
cudaMalloc(&B, 64 * 16 * 64 * 16 * 2);
cudaMalloc(&O, 64 * 16 * 64 * 16 * 2);
ker<0, 64, 64, 64> <<< 1, 32>>>(A, B, O);
ker<1, 64, 64, 64> <<< 1, 32>>>(A, B, O);
ker<2, 64, 64, 64> <<< 1, 32>>>(A, B, O);
ker<3, 64, 64, 64> <<< 1, 32>>>(A, B, O);
compile & bench commandline:
nvcc test2.cu -std=c++20 -arch native && ncu --section SchedulerStats --section WarpStateStats --section SourceCounters --section Occupancy -fo test2 ./a.out
nvcc versoin:
Copyright (c) 2005-2023 NVIDIA Corporation
Built on Fri_Jan__6_16:45:21_PST_2023
Cuda compilation tools, release 12.0, V12.0.140
Build cuda_12.0.r12.0/compiler.32267302_0
cuda version:
Driver Version: 550.40.07 CUDA Version: 12.4
result:
where should I fire this problem? here?
