hi
JP: 5.1.3
HW: orinnx16G
are there special tools for orinnx to test the DDR performance?
hi
JP: 5.1.3
HW: orinnx16G
To test the DDR performance on the Jetson Orin NX, specifically the hi JP 513 HW orinnx16G, you can use various tools and methods. Here’s a comprehensive overview:
tegrastats and tegra-uart, which can help you monitor and analyze the DDR performance.In comparison to other Jetson modules, the Orin NX has a similar DDR memory configuration to the Orin Nano, but with some differences in terms of memory bandwidth and performance. The Orin NX has a maximum memory bandwidth of 68.3 GB/s, while the Orin Nano has a maximum memory bandwidth of 51.2 GB/s.
To test the DDR performance on the Orin NX, you can follow these general steps:
tegrastats and tegra-uart tools to monitor and analyze the DDR performance in real-time.By following these steps and using the tools and methods described above, you can effectively test and optimize the DDR performance on the Jetson Orin NX hi JP 513 HW orinnx16G.
where is the MemBench
How to get these tools
It is a 3rdparty tool. Please check
GitHub - nicktehrany/membench: Benchmark to evaluate memory bandwidth/latency, page fault latency, and latency for mmap calls. Created for my BSc thesis on "Evaluating Performance Characteristics of the PMDK Persistent Memory Software Stack".
And you may also use
GitHub - akopytov/sysbench: Scriptable database and system performance benchmark
GitHub - ColinIanKing/stress-ng: This is the stress-ng upstream project git repository. stress-ng will stress test a computer system in various selectable ways. It was designed to exercise various physical subsystems of a computer as well as the various operating system kernel interfaces.
While running the benchmark, you can run $ sudo tegrastats to get system status.
