• Hardware Platform (Jetson / GPU) : Jetson Orin Nano • DeepStream Version: 7.1 • JetPack Version (valid for Jetson only): 6.2 • TensorRT Version: 10.3.0.30 • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Hi Everyone,
Do you want to tracking object separately between two cameras? Or you want to tracking object across cameras?
I wanna track object across the cameras. Is it possible using deepstream and is there any examples available that i could use as reference?
You can ask questions about MTMC on jetson under this topic. I don’t know much about it.
Currently only GPU is supported, probably for accuracy reasons
