How to Upgrade JEtpack
Is there a way to upgrade Jetpack 4.3 to 4.4, Because my xavier came with Jetpack 4.3 default, I know how to use SDK manager and flash it, but I just want to know if there is any way to directly upgrade to 4.4 using commands in terminal.
I recommend you can use the SDK Manager to upgrade the jetpack to 4.4
nishad1092,
hope to be helpful in your case:
https://docs.nvidia.com/jetson/jetpack/install-jetpack/index.html#upgrade-jetpack
I just wanted to know if there is any way to use without SDK, because Im having trouble accessing my Ubuntu OS from System, and SDK manager has to be started through Ubuntu isn’t ,… So thats why I wanted to knw easy way to directly use command from xavier
Hi, Im little scared to use the upgrade command, Because last time I used a sudo upgrade command and it messed the entire Xavier.
Im looking to do this because Xavier has a ai model running which used jetpack 4.4, and since it doesnt have 4.4, I dont know if thats the reason, Xavier keeps restarting,
Xavier keeps restarting, do u think its cuz it doesnt have a jetpack 4.4, where in the application demands it.
It helped, Thank u @MtHiker
