I want to upgrade the storage of the SSD card of Nvidia NX from 128G to 1T. Since I’ve already switch the roofs from SD to the 128GB SSD, which means I made Xavier boot from the original SSD card. So should I just directly remove the original SSD and put in a new empty SSD card? Or I need to do something else before I put in the new SSD card? Thanks for your help!!
You need to put in a new empty SSD, then switch the roofs from SD to the new SSD as whatyou did last time.
