Hey I m trying to use rotation spatial augmentation in the TLT training pipeline but It is not working
spatial_augmentation {
hflip_probability: 0.5
vflip_probability: 0.0
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
rotation_angle_max: 30.0
rotation_units: "degrees"
Error: google.protobuf.text_format.ParseError: 48:5 : Message type “AugmentationConfig.SpatialAugmentation” has no field named “rotation_angle_max”.
I tried the way mentioned here in the documentation which tells us to use it like this
rotation_config{
angle: 5.0
units: "degrees"
But it is also not working, and I see that the code is not open source.
So please tell me the right FIELD name which can be used for using the rotation Augmentation in the detection pipeline.
https://docs.nvidia.com/metropolis/TLT/tlt-user-guide/text/object_detection/offline_data_augmentation.html#id3
Please note that it is only compatible with the tool augment. See https://docs.nvidia.com/metropolis/TLT/tlt-user-guide/text/object_detection/offline_data_augmentation.html#offline-data-augmentation
In order to circumvent this and generate a dataset with the required augmentations and give control to the user, TLT provides an offline augmentation tool called augment .
Please download latest jupyter notebook.
see
https://docs.nvidia.com/metropolis/TLT/tlt-user-guide/text/quickstart/deepstream_integration.html#download-jupyter-notebook
wget --content-disposition https://api.ngc.nvidia.com/v2/resources/nvidia/tlt_cv_samples/versions/v1.0.2/zip -O tlt_cv_samples_v1.0.2.zip
unzip -u tlt_cv_samples_v1.0.2.zip -d ./tlt_cv_samples_v1.0.2 && rm -rf tlt_cv_samples_v1.0.2.zip && cd ./tlt_cv_samples_v1.0.2
then, go into tlt_cv_samples_v1.0.2/augment.
There is augment.ipynb and its specs folder.
# Spec file for tlt-augment.
spatial_config{
rotation_config{
angle: 10.0
units: “degrees”
dataset_config{
image_path: “image_2”
label_path: “label_2”
color_config{
hue_saturation_config{
hue_rotation_angle: 5.0
saturation_shift: 1.0
output_image_width: 1248
output_image_height: 384
output_image_channel: 3
image_extension: “.png”
