I have a project composed by .cpp file calling .cu file. For example
.cpp file
int main(){
kernel();
.cu file
kernel(){
-g -G option has been added in Makefile for .cu file. .cpp file is built with regular gcc.
The resulting .o files are : main.o, kernel.cu_o
I want to use cuda-gdb to check data on device side. However, when I used cuda-gdb main, it can not enter kernel(); if I used cuda-gdb kernel, there is segment error and core is dumped.
Anyone knows how to debug this structure?
