hey,guys,
I can’t step into my kernel code when I use cuda-gdb 3.0. And my develop enviroment is: ubuntu 9.10, cuda toolkit3.0, gtx 480, gcc 4.3.
In my makefile, I use"include ./…/…/common/common.mk", and I modified the common.mk at the line which defined NVCCFLAGS:
NVCCFLAGS:= -g ï¼G
[/codeï¼½
also commented the
[code]
//GENCODE_SM10 := -gencode=arch=compute_10,code=\"sm_10,compute_10\"
when I went to the statement “cudaMalloc”, I get the error " Segment fault".
If I only modified the complie command to add “-g -G” after $NVCCFLAGS just like below:
$(OBJDIR)/%.cu.o : $(SRCDIR)%.cu $(CU_DEPS)
$(VERBOSE)$(NVCC) $(GENCODE_SM10) $(GENCODE_ARCH) $(GENCODE_SM20) $(NVCCFLAGS) <b><u>-g -G </u></b>$(SMVERSIONFLAGS) -o $@ -c $<
and my .cu file and .cpp file:
CUFILES_sm_20 := mytest.cu \
# CUDA dependency files
CU_DEPS := mytest_kernel.cu \
# C/C++ source files (compiled with gcc / c++)
CCFILES := init.cpp \
I compiled it using " make dbg=1".
I set the breakpoint in the kernel: “b mytest_kernel.cu: 15”
run…
and Cant get into the kernel.
Any suggestion?
