I’m trying to debug the CUDA code, but I can’t step into any kernel function. I always get to the line, where the kernel function is called, then if I try to step in, the gdb outputs an information about new thread, but does not actually step in.
I tried to put some breakpoints into the kernel functions, but it still does not break on them.
Could anyone give me some advices. I would greatly appreciate any help on debugging kernel functions in any linux IDE (it doesn’t have to be gdb). Thanks
Thanks… ehm… I have to admit my own stupidity. The compiler flags were OK, even on the very beginning of my debugging attemps. However, why I expected the kernel function to be executed, when the block dimension was set to (1,0,0), is the correct question, I should have asked myself first External Image.
Well, prof. Farnsworth would probably say:
“So, that’s what things would be like if I did invented the fing-longer… ohh… a man can dream… a man can dream.”
