Hello Everyone!
I have a simple kernel that performs some linear algebra operations like Gauss Elimination, Matrix Vector Product, etc. A few days ago, I began to notice some issues while debugging my case with cuda-gdb in VSCode.
Firstly, the commands required to change the CUDA focus started to become irresponsive. For example, running cuda thread 0 did not switch to the first thread as I was expecting it to.
Owing to this, I updated my CUDA version from 12.5 to 12.9 and it seemed to be fixed. But this is where other issues began to crop up.
I am no longer able to step into my kernels with GDB in VSCode. My grid dimensions are (3,1,1) and my block is deployed with 512 threads. GDB exits out with the following error message.
warning: Warp(s) other than the current warp had to be single-stepped:0x00000000009ffff7
cuda-gdb/14/gdb/gdbarch.c:2408: internal-error: gdbarch_dummy_id: Assertion `gdbarch->dummy_id != NULL' failed.
A problem internal to GDB has been detected,
further debugging may prove unreliable.
----- Backtrace -----
Backtrace unavailable
Quit this debugging session? (y or n) [answered Y; input not from terminal]
This is a bug, please report it. For instructions, see:
<https://forums.developer.nvidia.com/c/developer-tools/cuda-developer-tools/cuda-gdb>.
Create a core file of GDB? (y or n) [answered Y; input not from terminal]
I will also include the outputs of the nvidia-smi commands and the nvcc versions as well. CUDA-12.9 is installed properly and the debugger path is pointing to the right place.
| NVIDIA-SMI 575.64.03 Driver Version: 575.64.03 CUDA Version: 12.9 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3060 ... Off | 00000000:01:00.0 On | N/A |
| N/A 45C P3 24W / 80W | 1096MiB / 6144MiB | 25% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1017 G /usr/lib/xorg/Xorg 317MiB |
| 0 N/A N/A 1647 G cinnamon 119MiB |
| 0 N/A N/A 3164 G /usr/lib/firefox/firefox 255MiB |
| 0 N/A N/A 35966 G /usr/lib/firefox/firefox 202MiB |
| 0 N/A N/A 37644 G /usr/lib/firefox/firefox 95MiB |
Copyright (c) 2005-2025 NVIDIA Corporation
Built on Tue_May_27_02:21:03_PDT_2025
Cuda compilation tools, release 12.9, V12.9.86
Build cuda_12.9.r12.9/compiler.36037853_0
