Hi all,
I’m trying to a debug my code using cuda-gdb. When I compile the cuda file using:
nvcc -gencode=arch=compute_20,code=\"sm_20,compute_20\" test.cu
OR
nvcc -arch=sm_20 test.cu
I can execute the program with no segmentation fault. However, when I compile using the following command for debugging:
nvcc -g -G -gencode=arch=compute_20,code=\"sm_20,compute_20\" test.cu
OR
nvcc -g -G -arch=sm_20 test.cu
I get a segmentation fault at line 2 in the following example while debugging:
1 myType* dev_myTypes;
2 cudaMalloc((void**) &dev_myTypes, SIZE * sizeof(myType));
3 cudaMemcpy ( dev_myTypes, myTypes, SIZE * sizeof(myType),
4 cudaMemcpyHostToDevice);
I’m using CUDA 3.2 on a 480 card on Linux.
Am I missing something? Any thoughts on this?
Thanks much.
