I am currently trying to use cuFFT lib to do a up sampling process, the process is like:
do a FFT to get a fft result say: 1111111111
then put them in a bigger array : 000000000011111111110000000000
then do a iFFT to get a up sampled result.
But it looks like cuFFT handles data differently I can’t get the results I needed, I am suspecting that in the case of cuFFT, I should not put data in the bigger array like I did in the 2 step, do you guys have any idea how should I handle the data in the second step?
With most FFT routines the lower frequencies will be in the corners not at the center. So when you stick your date into a larger array, you also want to put it at the corners and pad the zeros into the middle.
