How to use custom RL network in Isaacgym
Can I use a custom network structure and algorithm in Isaacgym for the reinforcement learning part? If I want to change the reinforcement learning algorithm, in which files do I need to make changes, and where do I need to access my own algorithm?
Hi @user8193
I encourage you to try skrl (SKRL - Reinforcement Learning library (0.7.0) — skrl 0.7.0 documentation), a modular RL library designed to put in the hands of researchers the control of the RL system. It is focused on readability, transparency and simplicity of the code, where each class inherits from one and only one base class that provides a common interface (no need to navigate through half a dozen files to identify how the algorithms work).
This library allows you to create and use custom networks as shown below and to implement your own algorithms (see basic inheritance usage)
Please, visit the documentation for usage details and examples
class Policy(GaussianModel):
    def __init__(self, observation_space, action_space, device, clip_actions=False,
                 clip_log_std=True, min_log_std=-20, max_log_std=2):
        super().__init__(observation_space, action_space, device, clip_actions,
                         clip_log_std, min_log_std, max_log_std)
        self.linear_layer_1 = nn.Linear(self.num_observations, 32)
        self.linear_layer_2 = nn.Linear(32, 32)
        self.mean_action_layer = nn.Linear(32, self.num_actions)
        self.log_std_parameter = nn.Parameter(torch.zeros(self.num_actions))
    def compute(self, states, taken_actions):
        x = F.elu(self.linear_layer_1(states))
        x = F.elu(self.linear_layer_2(x))
        return torch.tanh(self.mean_action_layer(x)), self.log_std_parameter
class Value(DeterministicModel):
    def __init__(self, observation_space, action_space, device, clip_actions=False):
        super().__init__(observation_space, action_space, device, clip_actions)
        self.net = nn.Sequential(nn.Linear(self.num_observations, 32),
                                 nn.ELU(),
                                 nn.Linear(32, 32),
                                 nn.ELU(),
                                 nn.Linear(32, 1))
        return self.net(states)
networks = {"policy": Policy(env.observation_space, env.action_space, device, clip_actions=True),
            "value": Value(env.observation_space, env.action_space, device)}
It’s definitely possible to use your own RL algorithm with Isaac Gym. You’ll want to create your own launcher script, similar to train.py in the IsaacGymEnvs repo, and make sure all of the APIs required by your RL library is present in vec_task.py
