Jetson AGX Orin
• DeepStream Version
deepstream-6.2
JetPack 5.1.1
• TensorRT Version
questions
- Using the following command, you will get “RGB/BGR Format transformation is not supported by VIC use GPU instead”:
gst-launch-1.0 -v nvv4l2camerasrc device=/dev/video0 ! "video/x-raw(memory:NVMM),format=UYVY,width=1920,height=1536,framerate=30/1" ! nvvideoconvert name=start ! "video/x-raw(memory:NVMM),format=NV12" ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=RGB" ! fpsdisplaysink name=rec text-overlay=false video-sink=fakesink sync=false
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
/GstPipeline:pipeline0/GstFPSDisplaySink:rec/GstFakeSink:fakesink0: sync = false
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstNvV4l2CameraSrc:nvv4l2camerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1536, format=(string)UYVY, interlace-mode=(string)progressive, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1536, format=(string)UYVY, interlace-mode=(string)progressive, framerate=(fraction)30/1
/GstPipeline:pipeline0/Gstnvvideoconvert:start.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1536, interlace-mode=(string)progressive, framerate=(fraction)30/1, format=(string)NV12, block-linear=(boolean)false
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1536, interlace-mode=(string)progressive, framerate=(fraction)30/1, format=(string)NV12, block-linear=(boolean)false
/GstPipeline:pipeline0/Gstnvvideoconvert:nvvideoconvert1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1536, interlace-mode=(string)progressive, framerate=(fraction)30/1, format=(string)RGB, block-linear=(boolean)false
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1536, interlace-mode=(string)progressive, framerate=(fraction)30/1, format=(string)RGB, block-linear=(boolean)false
/GstPipeline:pipeline0/GstFPSDisplaySink:rec.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1536, interlace-mode=(string)progressive, framerate=(fraction)30/1, format=(string)RGB, block-linear=(boolean)false
/GstPipeline:pipeline0/GstFPSDisplaySink:rec/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1536, interlace-mode=(string)progressive, framerate=(fraction)30/1, format=(string)RGB, block-linear=(boolean)false
/GstPipeline:pipeline0/GstFPSDisplaySink:rec.GstGhostPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1536, interlace-mode=(string)progressive, framerate=(fraction)30/1, format=(string)RGB, block-linear=(boolean)false
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1536, interlace-mode=(string)progressive, framerate=(fraction)30/1, format=(string)RGB, block-linear=(boolean)false
/GstPipeline:pipeline0/Gstnvvideoconvert:nvvideoconvert1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1536, interlace-mode=(string)progressive, framerate=(fraction)30/1, format=(string)NV12, block-linear=(boolean)false
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1536, interlace-mode=(string)progressive, framerate=(fraction)30/1, format=(string)NV12, block-linear=(boolean)false
/GstPipeline:pipeline0/Gstnvvideoconvert:start.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1536, format=(string)UYVY, interlace-mode=(string)progressive, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1536, format=(string)UYVY, interlace-mode=(string)progressive, framerate=(fraction)30/1
ERROR: from element /GstPipeline:pipeline0/GstNvV4l2CameraSrc:nvv4l2camerasrc0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline0/GstNvV4l2CameraSrc:nvv4l2camerasrc0:
streaming stopped, reason error (-5)
Execution ended after 0:00:00.122440064
Setting pipeline to NULL ...
Freeing pipeline ...
- Using the following command, you will see that the CPU is occupied by 100% and there is no output of the image:
gst-launch-1.0 -v nvv4l2camerasrc device=/dev/video0 ! "video/x-raw(memory:NVMM),format=UYVY,width=1920,height=1536,framerate=30/1" ! nvvideoconvert name=start ! "video/x-raw(memory:NVMM),format=NV12" ! nvvideoconvert compute-hw=GPU gpu-id=0 nvbuf-memory-type=0 ! "video/x-raw(memory:NVMM),format=RGB" ! fpsdisplaysink name=rec text-overlay=false video-sink=fakesink sync=false
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:08.005417920
