Software Version
DRIVE OS 6.0.6
[√] DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[√] Linux
QNX
other
Hardware Platform
[√] other
SDK Manager Version
1.9.2.10884
[√] other
Host Machine Version
[√] other
I am using nvsipl to capture images from a camera. Since the camera has its own ISP, I am getting YUYV format images directly from the ICP.
The issue now is that NvMedia API requires images in YUV420 format, and I want to convert the YUYV format image to YUV420. I plan to use the NvMediaCompose() function in NvMedia2D to perform the conversion, but I am getting an error when I call NvMedia2DSetSrcNvSciBufObj().
Can you help me identify the problem or provide some sample code for this format conversion?
The error message I am getting when calling the API is as follows:"
**Apr 19 09:38:32 tegra-ubuntu DULE: Module_id 22 Severity 6 : NvMediaICPCreateEx 72 **
**Apr 19 09:38:32 tegra-ubuntu DULE: Module_id 22 Severity 6 : T23x VI version 0x000023 **
**Apr 19 09:38:32 tegra-ubuntu DULE: Module_id 48 Severity 2 : failed to set source buffer, conversion to surface container failed **
**Apr 19 09:38:32 tegra-ubuntu DULE: Module_id 48 Severity 2 : failed to set NvMedia2D source buffer, error 1 **
Apr 19 09:38:32 tegra-ubuntu DULE: Module_id 48 Severity 2 : failed to get NvMedia2D compose parameters 9
