As I know, Using converted tensor rt model is only support same tensor rt environment. (ex. If I converted the model by using tensor rt in Jetson orin nano system, This converted tensor rt model only can run in jetson orin nano system.) I just checked this issue, when I converted model by using tensor rt in Jetson orin nano system, this converted model can run/inference on another Jetson orin nano system.
But I just wanna deploy tensor rt model more easy and comfortable. This process is not easy to anyone and uncomfortable. I wanna convert the model by using tensor rt on desktop PC environment. So I tried, but some problem is occurred. Belows are some problems when I convert the tensor rt model on desktop PC environment and apply on Jetson orin nano system.
- It is impossible to match the versions of PC and onboard (jetson orin nano) environment. How can I install same version of tensor rt, cuDNN, CUDA, etc packages?
- As I know, Converting the model by using tensor RT has huge dependancy of packages version such as cuDNN, CUDA etc. I was installed Jetpack 6.0 to Jetson orin nano board by using Nvidia SDK program, this Jetpack has default version of packages. (Tensor RT: 8.6.2.3, cuDNN: 8.9.4, CUDA: 12.2). I searched the docker image which has same package version of onboard system in official website by Nvidia docker (Container Release Notes - NVIDIA Docs), but I can not find same version of onboard system.
- So I select the some docker images with most similar version of onboard system. (docker image version : 23.06 to 24.02) I adapt these docker images on my desktop pc, convert the model by using tensor rt. After finish these process, I load the tensor rt converted model (onnx & trt file) on Jetson orin nano system and run inference, It returns error like this. âThe engine plan file is not compatible with this version of Tensor RT, expecting library version 8.6.2.3 got 8.6.1.6, please rebuild.â
So I just wanna know the way for apply the tensor rt model which converted on desktop pc environment on onboard system such as Jetson orin nano. How should I do to solve this issue? Please help me.
