Marking the kernel at launch with a launch attribute (runtime) / launch attribute (driver) during cuda stream capture.
Runtime:
cudaLaunchAttributeValue::@31 cudaLaunchAttributeValue::deviceUpdatableKernelNode [inherited]
Value of launch attribute cudaLaunchAttributeDeviceUpdatableKernelNode with the following fields:
Here, under enum cudaLaunchAttributeID and value cudaLaunchAttributeDeviceUpdatableKernelNode=13 it is mentioned":
Valid for graph nodes, launches. This attribute is graphs-only, and passing it to a launch in a non-capturing stream will result in an error. :cudaLaunchAttributeValue::deviceUpdatableKernelNode::deviceUpdatable can only be set to 0 or 1. Setting the field to 1 indicates that the corresponding kernel node should be device-updatable. On success, a handle will be returned via cudaLaunchAttributeValue::deviceUpdatableKernelNode::devNode which can be passed to the various device-side update functions to update the node’s kernel parameters from within another kernel. For more information on the types of device updates that can be made, as well as the relevant limitations thereof, see cudaGraphKernelNodeUpdatesApply. Nodes which are device-updatable have additional restrictions compared to regular kernel nodes. Firstly, device-updatable nodes cannot be removed from their graph via cudaGraphDestroyNode. Additionally, once opted-in to this functionality, a node cannot opt out, and any attempt to set the deviceUpdatable attribute to 0 will result in an error. Device-updatable kernel nodes also cannot have their attributes copied to/from another kernel node via cudaGraphKernelNodeCopyAttributes. Graphs containing one or more device-updatable nodes also do not allow multiple instantiation, and neither the graph nor its instantiated version can be passed to cudaGraphExecUpdate. If a graph contains device-updatable nodes and updates those nodes from the device from within the graph, the graph must be uploaded with cuGraphUpload before it is launched. For such a graph, if host-side executable graph updates are made to the device-updatable nodes, the graph must be uploaded before it is launched again.
Driver:
CUlaunchAttributeValue::@10 CUlaunchAttributeValue::deviceUpdatableKernelNode [inherited]
Value of launch attribute CU_LAUNCH_ATTRIBUTE_DEVICE_UPDATABLE_KERNEL_NODE with the following fields:
Here, under enum CUlaunchAttributeID and value CU_LAUNCH_ATTRIBUTE_DEVICE_UPDATABLE_KERNEL_NODE=13 (This enum value is mentioned here) it is mentioned:
Valid for graph nodes, launches. This attribute is graphs-only, and passing it to a launch in a non-capturing stream ….
In simple words, The runtime exposes a launch attribute cudaLaunchAttributeDeviceUpdatableKernelNode. When you set it for a kernel launch, CUDA will return a cudaGraphDeviceNode_t in the attribute’s value; you then copy that handle to device memory. This seem to work with stream capture so the kernel ends up as a node in your captured graph and you get its device-updatable handle.
// mark_kernel_at_launch.cu
#include <iostream>
#include <cublas_v2.h>
#include <cuda_runtime.h>
#include <vector>
#include <cuda.h>
#define CUDA_SAFECALL(call) \
call; \
cudaError err = cudaGetLastError(); \
if (cudaSuccess != err) { \
fprintf( \
stderr, \
"Cuda error in function '%s' file '%s' in line %i : %s.\n", \
#call, __FILE__, __LINE__, cudaGetErrorString(err)); \
fflush(stderr); \
exit(EXIT_FAILURE); \
#define SAFECALL_DRV(call) \
CUresult err = call; \
if (err != CUDA_SUCCESS) { \
const char *errStr; \
cuGetErrorString(err, &errStr); \
fprintf( \
stderr, \
"CUDA Driver API error in function '%s' file '%s' in line %i : %s.\n", \
#call, __FILE__, __LINE__, errStr); \
fflush(stderr); \
#define CUBLAS_CALL(func) \
cublasStatus_t s = (func); \
if(s != CUBLAS_STATUS_SUCCESS) { \
std::cerr << "cuBLAS Error: " << s << " at line " << __LINE__ << std::endl; \
const int N = 1024; // Dimension of the square matrix (N x N)
// Helper function to initialize matrices
void initializeMatrix(float* matrix, int n, float value) {
for (int i = 0; i < n * n; ++i) {
matrix[i] = value;
void printMatrix(float* matrix, int n) {
for (int i = 0; i < n; ++i) {
for (int j = 0; j < n; ++j) {
std::cout << matrix[i * n + j] << " ";
std::cout << std::endl;
// CUDA kernel that adds two vectors, each thread handles one element of c
__global__ void vecAdd(float *a, float *b, float *c, int n) {
if(threadIdx.x == 0 && blockIdx.x == 0) {
printf("vecAdd kernel launched with %d blocks of %d threads; n = %d\n", gridDim.x, blockDim.x, n);
int id = blockIdx.x * blockDim.x + threadIdx.x;
if (id < n) c[id] = a[id] + b[id];
__device__ cudaGraphDeviceNode_t g_vecadd_node_handle;
__global__ void tweak_node() {
// enable (or disable) the node
cudaGraphKernelNodeSetEnabled(g_vecadd_node_handle, true);
// change grid size (example)
cudaGraphKernelNodeSetGridDim(g_vecadd_node_handle, dim3(512,1,1));
// update a param (example): offset is ABI-dependent; if vecAdd args are
// (float*, float*, float*, int), the int may come after 3 pointers.
int newN = 4096;
size_t offset = 3 * sizeof(void*); // typical on 64-bit, for illustration
cudaGraphKernelNodeSetParam(g_vecadd_node_handle, offset, &newN, sizeof(newN));
// or do a batch with cudaGraphKernelNodeUpdatesApply(...)
int main() {
// Initialize cuBLAS
cublasHandle_t handle;
CUBLAS_CALL(cublasCreate(&handle));
// Create a CUDA stream
cudaStream_t stream;
CUDA_SAFECALL(cudaStreamCreate(&stream));
// Set cuBLAS to use the created stream
CUBLAS_CALL(cublasSetStream(handle, stream));
// Allocate memory for input and output matrices on host
// A * B = C
float* h_A = (float*) malloc(N * N * sizeof(float));
float* h_B = (float*) malloc(N * N * sizeof(float));
float* h_C = (float*) malloc(N * N * sizeof(float));
initializeMatrix(h_A, N, 1.0f); // Matrix A with all elements 1.0
initializeMatrix(h_B, N, 2.0f); // Matrix B with all elements 2.0
// Allocate memory on device
float *d_A, *d_B, *d_C;
CUDA_SAFECALL(cudaMalloc((void**)&d_A, N * N * sizeof(float)));
CUDA_SAFECALL(cudaMalloc((void**)&d_B, N * N * sizeof(float)));
CUDA_SAFECALL(cudaMalloc((void**)&d_C, N * N * sizeof(float)));
// Copy data from host to device (Async using stream)
CUDA_SAFECALL(cudaMemcpyAsync(d_A, h_A, N * N * sizeof(float), cudaMemcpyHostToDevice, stream));
CUDA_SAFECALL(cudaMemcpyAsync(d_B, h_B, N * N * sizeof(float), cudaMemcpyHostToDevice, stream));
// Create CUDA Graph
cudaGraph_t graph;
cudaGraphExec_t instance;
// Begin CUDA Graph capture
cudaStreamBeginCapture(stream, cudaStreamCaptureModeGlobal);
// launch the tweaker kernel (still inside stream capture)
tweak_node<<<1,1,0,stream>>>();
# if 1
//testing a vecAdd kernel
int blockSize, gridSize;
blockSize = 1024;
gridSize = (int)ceil((float)N / blockSize);
//build extensible launch config with the "device-updatable" attribute
cudaLaunchAttribute attr{};
attr.id = cudaLaunchAttributeDeviceUpdatableKernelNode;
attr.val.deviceUpdatableKernelNode.deviceUpdatable = 1;
attr.val.deviceUpdatableKernelNode.devNode = 0;
cudaLaunchConfig_t cfg{};
cfg.gridDim = dim3(gridSize, 1, 1);
cfg.blockDim = dim3(blockSize, 1, 1);
cfg.dynamicSmemBytes = 0;
cfg.stream = stream;
cfg.attrs = &attr;
cfg.numAttrs = 1;
// launch (still inside stream capture)
CUDA_SAFECALL(cudaLaunchKernelEx(&cfg, vecAdd, d_A, d_B, d_C, N));
cudaGraphDeviceNode_t host_devnode = attr.val.deviceUpdatableKernelNode.devNode;
#endif
// Set up GEMM (Matrix Multiplication)
float alpha = 1.0f, beta = 0.0f;
// cublasSgemm performs matrix multiplication C = alpha * A * B + beta * C
// where A, B, C are NxN matrices in column-major order.
CUBLAS_CALL(cublasSgemm(handle,
CUBLAS_OP_N, CUBLAS_OP_N,
N, N, N,
&alpha,
d_A, N,
d_B, N,
&beta,
d_C, N));
// End CUDA Graph capture
cudaStreamEndCapture(stream, &graph);
// Instantiate the graph
cudaGraphInstantiate(&instance, graph, NULL, NULL, 0);
cuGraphUpload(instance, stream);
// After the call, host_devnode now holds the device-updatable node handle.
// Stash it in a __device__ global so kernels can use it:
CUDA_SAFECALL(cudaMemcpyToSymbol(g_vecadd_node_handle, &host_devnode,
sizeof(host_devnode)));
printf("device-updatable node handle: %p\n", (void*)host_devnode);
// Get the number of nodes to allocate an array of nodes
cudaGraphNode_t* nodes=NULL;
size_t numNodes=0;
CUDA_SAFECALL((cudaGraphGetNodes(graph, nodes, &numNodes)));
nodes = (cudaGraphNode_t*)malloc(numNodes*sizeof(cudaGraphNode_t));
std::vector<cudaGraphNode_t> kernelNode;
printf("Number of nodes: %lu\n", numNodes);
for(int i = 0; i < numNodes; i++){
cudaGraphNodeType type;
cudaGraphNodeGetType(nodes[i], &type);
if (type == cudaGraphNodeTypeKernel){
printf("Node %d is kernel Node\n", i+1);
kernelNode.push_back(nodes[i]);
else if(type == cudaGraphNodeTypeMemset){
printf("Node %d is memset Node\n", i+1);
else if(type == cudaGraphNodeTypeMemAlloc){
printf("Node %d is memory allocation Node\n", i+1);
else if(type == cudaGraphNodeTypeMemFree){
printf("Node %d is memory free Node\n", i+1);
else{
printf("Node %d is unknown type Node\n", i+1);
// Launch the instantiated graph
cudaGraphLaunch(instance, stream);
cudaStreamSynchronize(stream);
printf("Graph launched successfully.\n");
// Copy result from device to host (Async using stream)
CUDA_SAFECALL(cudaMemcpyAsync(h_C, d_C, N * N * sizeof(float), cudaMemcpyDeviceToHost, stream));
// Wait for the stream to finish all operations
CUDA_SAFECALL(cudaStreamSynchronize(stream));
// // Print the result matrix C
// std::cout << "Matrix C (Result of A * B):" << std::endl;
// printMatrix(h_C, N);
// Cleanup
CUBLAS_CALL(cublasDestroy(handle));
CUDA_SAFECALL(cudaFree(d_A));
CUDA_SAFECALL(cudaFree(d_B));
CUDA_SAFECALL(cudaFree(d_C));
free(h_A);
free(h_B);
free(h_C);
// Destroy the stream
CUDA_SAFECALL(cudaStreamDestroy(stream));
return 0;
$ nvcc mark_kernel_at_launch.cu -o mark_kernel_at_launch -lcublas -lcuda
$ ./mark_kernel_at_launch
device-updatable node handle: 0x790d2ac74400
Number of nodes: 3
Node 1 is kernel Node
Node 2 is kernel Node
Node 3 is kernel Node
vecAdd kernel launched with 512 blocks of 1024 threads; n = 4096
