It seems from my googling that I need to use the J6 pins, but I can’t find J6 anywhere on the TX2 dev board. I can find J4 (labeled PNL PWR / LED) and J8 labaled (GND / SOC ONLY RST). I see J14 and a bunch of pins, J20 and a bunch of pins, etc.
I have a modified case to throw the TX2 in with the NVME drive I have installed via a riser, but just need a way to turn this board on without having to open the case every time.
Any help? Pic would be most helpful. I have a two pin “POWER SW” cable coming off the case. One yellow one black.
The two pin 0.1" headers next to the buttons can be momentarily shorted to do the same as tapping the button. One side is ground, the other side is active.
I have the same issue. The pins for J3, J4, J6, J9 seem to be missing on my new TX2. Could it be a change in recent carrier board design for TX2? I am trying to connect an external power button to the TX2 so that I can power it on using the button instead of pushing on S4. Thanks
Hi Trumany
I’m also interested in powering up the TX2 using pins on the board…Seems like I have the new revision of the board, I don’t have a J6 connector next to the power button
Is there a workaround for the new carrier board design?
Thanks for your comments. I solved problem. I found the explanation of J20 on tx2 board.
The jumpers of J3, J6, J9 (~B04) integrated into J20 (c02) but I couldn’t find this in the schematic packages.
The schematic package is too huge to find this for me. Anyway thanks again.
