the server at https://pypi.jetson-ai-lab.io/ appears to be down — I’m unable to access any Jetson-specific packages from this PyPI repository. This is currently blocking development workflows that rely on those packages.
Could you please confirm if this is a known issue, and whether there is an estimated time for resolution?
Also, are there any alternative repositories or mirrors we can use in the meantime?
Thanks in advance for your help!
I’d be happy to help you with your issue!
It appears that you’re experiencing difficulties accessing Jetson-specific packages from a PyPI repository due to a server issue. I’ve searched through the provided context, but unfortunately, I couldn’t find any specific information about the PyPI repository or the server issue you’re experiencing.
However, I can suggest some possible alternatives and troubleshooting steps:
- Check the NVIDIA Jetson forums: You can try searching the NVIDIA Jetson forums, specifically the Jetson AGX Orin forum, to see if anyone else is experiencing similar issues or if there are any known workarounds.
- Look for alternative repositories or mirrors: Although I couldn’t find any specific information about alternative repositories or mirrors, you can try searching for other PyPI repositories or mirrors that might host the Jetson-specific packages you need.
- Contact NVIDIA support: If you’re unable to find any solutions or workarounds, you can try contacting NVIDIA support directly to report the issue and ask for assistance. They may be able to provide more information about the server issue and an estimated time for resolution.
- Check the Jetson AGX Orin documentation: You can also review the Jetson AGX Orin documentation, such as the Jetson AGX Orin Platform Adaptation and Bring-Up guide, to see if there are any specific instructions or recommendations for accessing packages.
In comparison to other Jetson platforms, I didn’t find any specific information about PyPI repository issues on other platforms like Jetson AGX Xavier. However, it’s possible that similar issues might exist on other platforms, and searching the respective forums or documentation might yield more information.
In summary, while I couldn’t find a direct solution to your issue, I hope these suggestions help you troubleshoot and find alternative solutions. If you have any further questions or need more assistance, feel free to ask!
Thanks @carolyuu for the support.
https://pypi.jetson-ai-lab.io/ is now back online
And it’s down (502) again!
