Finally, I found that the frequency is possibly changed by tensorRT. Once I executed the inference, the frequency will change to the highest frequency.
tqxu
4
Related topics
| How to adjust the CPU and GPU frequency dynamically on Jetson TX2 with C/C++? | 4 | 3258 | October 18, 2021 | |
| GPU clock frequency | 14 | 2649 | August 9, 2023 | |
| AGX Orin with 32GB RAM set gpu frequency failed | 8 | 54 | March 23, 2026 | |
| Jetson AGX Orin 32GB Redcued GPU Frequency | 6 | 192 | November 27, 2025 | |
| Do Jetson series support NVML? | 2 | 217 | July 8, 2024 | |
| GPU clock manual setting | 3 | 3778 | October 18, 2021 | |
| Why does the GPU run at a frequency higher than the GPU operating frequency specified in the NVP model? | 11 | 796 | April 21, 2023 | |
| Cannot access or change GPU frequency on TX1. | 2 | 924 | October 18, 2021 | |
| Devkit,120w power mode, gpu freq can reach 1.574GHZ | 10 | 275 | December 19, 2025 | |
| How can I fix the GPU frequency on Xavier? | 2 | 926 | October 18, 2021 |
