I have tensorrt installed, but I get the error no module named’tensorrt’. The environment uses virtualenv.
Hi @kubo1,
The below link might address your query.
Kindly check.
ok. I read the link. Is there a way to use tensorRT on virtualenv without using anaconda?
Hi @kubo1,
Here the baseline is that tensorrt is installed in your virtual environment python and not on the system python.
Also you need to check if the LIB_PATH is set correctly.
@AakankshaS
ok. I solved. Thanks!
Can you help me out with this?
Hi @kubo1,
On the queries, CUDA Team should be able to assist you better.
ok. Thanks!
