Description
On my Jetson Xavier AGX, configured with Jetpack 4.4.1 I can not import tensorrt in Python3.6.
I have successfully installed the following packages, but tensorrt does not appear in the Python lib directories.
- nvidia-container-csv-tensorrt_7.1.3.0-1+cuda10.2_arm64.deb
- tensorrt_7.1.3.0-1+cuda10.2_arm64.deb
Environment
System: Jetson Xavier AGX
Jetpack Version: 4.4.1
TensorRT Version: 7.1.3.0 arm64
CUDA Version: 10.2
CUDNN Version: 8.0
Operating System + Version: Ubuntu 18.04
Python Version (if applicable): 3.6
Steps To Reproduce
From the host machine I have copied the aforementioned files to the Jetso Xavier via ssh.
scp ~/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-tensorrt_7.1.3.0-1+cuda10.2_arm64.deb xavier@192.168.1.110:/home/xavier/
scp ~/Downloads/nvidia/sdkm_downloads/tensorrt_7.1.3.0-1+cuda10.2_arm64.deb xavier@192.168.1.110:/home/xavier/
On the Jetson Xavier I have installed them the common way:
sudo dpkg -i nvidia-container-csv-tensorrt_7.1.3.0-1+cuda10.2_arm64.deb
sudo dpkg -i tensorrt_7.1.3.0-1+cuda10.2_arm64.deb
Hi @patrick.nagelm8t1h,
I suggest you to raise the concern in Jetson Xavier forum to get better assistance.
Please use JetPack to handle the installation for you.
If you want to do it manually, you will need all the following packages to make sure the functionality.
tensorrt_7.2.1.6-1+cuda10.2_arm64.deb
libnvinfer7_7.2.1-1+cuda10.2_arm64.deb
libnvinfer-dev_7.2.1-1+cuda10.2_arm64.deb
libnvinfer-bin_7.2.1-1+cuda10.2_arm64.deb
libnvinfer-doc_7.2.1-1+cuda10.2_all.deb
libnvinfer-samples_7.2.1-1+cuda10.2_all.deb
libnvinfer-plugin7_7.2.1-1+cuda10.2_arm64.deb
libnvinfer-plugin-dev_7.2.1-1+cuda10.2_arm64.deb
libnvparsers7_7.2.1-1+cuda10.2_arm64.deb
libnvparsers-dev_7.2.1-1+cuda10.2_arm64.deb
libnvonnxparsers7_7.2.1-1+cuda10.2_arm64.deb
libnvonnxparsers-dev_7.2.1-1+cuda10.2_arm64.deb
uff-converter-tf_7.2.1-1+cuda10.2_arm64.deb
graphsurgeon-tf_7.2.1-1+cuda10.2_arm64.deb
python-libnvinfer_7.2.1-1+cuda10.2_arm64.deb
python-libnvinfer-dev_7.2.1-1+cuda10.2_arm64.deb
python3-libnvinfer_7.2.1-1+cuda10.2_arm64.deb
python3-libnvinfer-dev_7.2.1-1+cuda10.2_arm64.deb
More, TensorRT requires CUDA and cuDNN pre-installed.
So if JetPack is an optional for you, it’s recommended to use JetPack for convience.
