WHile trying to run a python script with tensorrt as dependency, I’m getting import error.
To verify if tensorrt is there, i ran below commands,
sudo apt-get install tensorrt
Reading package lists… Done
Building dependency tree
Reading state information… Done
tensorrt is already the newest version (5.0.3.2-1+cuda10.0).
The following packages were automatically installed and are no longer required:
x11proto-dri2-dev x11proto-gl-dev
Use ‘sudo apt autoremove’ to remove them.
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Another,
dpkg -l | grep TensorRT
ii libnvinfer-dev 5.0.3-1+cuda10.0 arm64 TensorRT development libraries and headers
ii libnvinfer-samples 5.0.3-1+cuda10.0 all TensorRT samples and documentation
ii libnvinfer5 5.0.3-1+cuda10.0 arm64 TensorRT runtime libraries
ii tensorrt 5.0.3.2-1+cuda10.0 arm64 Meta package of TensorRT
I tried pip install tensorrt after the import error
This is error I get :
File “/usr/share/python-wheels/requests-2.18.4-py2.py3-none-any.whl/requests/models.py”, line 935, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 404 Client Error: Not Found for url: Links for tensorrt
JetPack installs TensorRT on Jetson Xavier device for you. It is not downloaded from the website like on desktop.
https://developer.nvidia.com/embedded/jetpack
Please refer below link to use the NVIDIA SDK Manager GUI to successfully configure your development environment:
https://docs.nvidia.com/sdk-manager/install-with-sdkm-jetson/index.html
I rechecked the installation of TensorRT with Jetson. the folder is present in /usr/src/tensorrt
with samples and bin.
When I check "import pycuda " in python/python3 shell, it is working.
But encounters ImportError when running “import tensorrt”.
As I mentioned in #1, my output for
shows tensorrt is present.
Also I ran the tensorrt sample codes, it is working.
Is there something else I need to do to make tensorrt work ? Any additional step ?
Can you try below commands on installed TRT directory:
Install the Python TensorRT wheel file.
cd TensorRT-${version}/python
If using Python 2.7:
sudo pip2 install tensorrt-*-cp27-none-linux_x86_64.whl
If using Python 3.x:
sudo pip3 install tensorrt-*-cp3x-none-linux_x86_64.whl
Also, please refer below link for steps 6,7,8 to install all the dependencies:
https://docs.nvidia.com/deeplearning/sdk/tensorrt-install-guide/index.html#installing-tar
I tried re-installing the SDK manager.
Some error in installing Tensorrt
19:51:42 ERROR : TensorRT on Target : : command safe_apt_install “sudo dpkg -i /opt/nvidia/deb_repos/libnvinfer-dev_6.0.1-1+cuda10.0_arm64.deb” 5; sleep 5; finished with error
19:51:42 ERROR : TensorRT on Target : command terminated with error
19:51:42 ERROR : TensorRT on Target : install ‘TensorRT on Target’ failure, command < cd ‘/home/honeywell-geforce-0001/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_L4T_TENSORRT_DLA_TARGET_POST_INSTALL_COMP’ -v=‘6.0’ -l=‘/home/honeywell-geforce-0001/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ -L=‘/home/honeywell-geforce-0001/.nvsdkm/logs/JetPack_4.3_Linux’ -p=‘23296’ -t=‘P2888’ -e=‘/home/honeywell-geforce-0001/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_6.0.1-1+cuda10.0_arm64.deb’ > terminated with error
Here is the screen shot for reference : https://i.imgur.com/IL14Z0q.png
Moving this to the Xavier forum so the Jetson team can take a look.
