I want to porting custom camera(isp not included) to the NVIDIA TX2.
Hi.
I want to porting a custom camera (ISP not included) to the NVIDIA TX2.
We have always used only cameras with built-in ISP.
So I lack knowledge of how to work.
If we use other image sensors besides the OV5693, OV23850, imx318 and imx390 which are included in the Jetpack SDK
• Device Tree in the Linux kernel
• V4L2 sensor driver
Can I just do the above two things?
Or
Do we need additional work on the ISP(Argus?) side?
Best Regards
Have a check this document
[url]Welcome — Jetson Linux<br/>Developer Guide 34.1 documentation
HI ShaneCCC
If you are tech supporter, I do not think such an answer is right.
Of course I am looking at the document.
I was wondering
Whether operation is required in addition to Device tree and V4l2 driver.
I believe the sensor programing guide should tell what you want.
HI
We implemented the driver and device tree by referring to the guide document.
I would like to help you do a preview test using gst-launch-1.0.
We confirmed it as follows.
(Node was created in / dev / video1.).
$ v4l2-ctl -d /dev/video1 --set-fmt-video=width=2304,height=1728,pixelformat=BG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw --verbose
VIDIOC_QUERYCAP: ok
VIDIOC_S_EXT_CTRLS: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture:
Width/Height : 2304/1728
Pixel Format : ‘BG10’
Field : None
Bytes per Line : 4608
Size Image : 7962624
Colorspace : sRGB
Transfer Function : Default
YCbCr Encoding : Default
Quantization : Default
Flags :
VIDIOC_REQBUFS: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_STREAMON: ok
Index : 0
Type : Video Capture
Flags : mapped, done
Field : None
Sequence : 0
Length : 7962624
Bytesused: 7962624
Timestamp: 241770.786463s (Monotonic, End-of-Frame)
[241765.456550] tegra-vi4 15700000.vi: Status: 5 channel:00 frame:880F
[241765.462993] tegra-vi4 15700000.vi: timestamp sof 241770919767264 eof 241770919900256 data 0x00000001
[241765.473092] tegra-vi4 15700000.vi: capture_id 30 stream 2 vchan 0
VIDIOC_STREAMOFF: ok
$ hexdump test.raw
0000000 0120 00e0 00f0 0110 0100 0100 0130 0100
0000010 0120 0120 0100 0120 0110 0110 0110 0120
0000020 0120 0110 0130 0100 0110 0100 0100 0120
0000030 0130 00f0 0100 00f0 0100 00f0 0120 0120
0000040 0150 0110 00e0 00d0 00f0 0100 0120 0110
0000050 0120 0110 0120 0110 0100 0100 0120 0120
I did
$ gst-launch-1.0 nvcamerasrc sensor-id=1 ! ‘video/x-raw(memory:NVMM),width=2304, height=1728, framerate=30/1, format=NV12’ ! nvoverlaysink -ev
Setting pipeline to PAUSED …
[242153.869242] pgd = ffffffc1a7888000
[242153.872768] [00000000] *pgd=000000022cbf8003, *pud=000000022cbf8003, *pmd=0000000000000000
[242153.881250] Library at 0x402efc: 0x400000 /usr/sbin/nvcamera-daemon
[242153.887603] Library at 0x402ef8: 0x400000 /usr/sbin/nvcamera-daemon
[242153.893963] vdso base = 0x7fa34e7000
Socket read error. Camera Daemon stopped functioning…
gst_nvcamera_open() failed ret=0
ERROR: Pipeline doesn’t want to pause.
ERROR: from element /GstPipeline:pipeline0/GstNvCameraSrc:nvcamerasrc0: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Additional debug info:
gstbasesrc.c(3354): gst_base_src_start (): /GstPipeline:pipeline0/GstNvCameraSrc:nvcamerasrc0:
Failed to start
Setting pipeline to NULL …
Freeing pipeline …
I am asking if it is a problem with the driver and the device tree or if the test method is wrong.
It could be the device tree cause the problem.
Remove the “sensor-id=1” to try the video node not necessary equal the sensor-id.
Also have a reference to below link to enable debug log to get more information.
https://elinux.org/Jetson_TX2_Camera_BringUp
HI ShaneCCC
Thank you for answer.
There are three camera nodes /dev/video0 and /dev/video1 ./dev/video2.
Actually the connection has been made to /dev/video1.
Can I not specifically set the connection to which node?
This is the result of running at a higher log level.
root@tegra-ubuntu:/home/nvidia# gst-launch-1.0 -v nvcamerasrc ! ‘video/x-raw(memory:NVMM),width=2304, height=1728, framerate=30/1, format=NV12’ ! nvoverlaysink -ev
Thread 1 getting next capture
Thread 2 getting next capture
Thread 3 getting next capture
Thread 2 is waiting
Thread 3 is waiting
Thread 4 getting next capture
Thread 1 is waiting
Thread 4 is waiting
Thread 5 getting next capture
Thread 5 is waiting
Thread 6 getting next capture
Thread 6 is waiting
Thread 7 getting next capture
Thread 7 is waiting
Thread 8 getting next capture
Thread 8 is waiting
Thread 9 getting next capture
Thread 9 is waiting
Thread 10 getting next capture
Thread 10 is waiting
Thread 11 getting next capture
Thread 11 is waiting
Thread 12 getting next capture
Thread 12 is waiting
Starting services…
Worker thread IspHw statsComplete start
Worker thread IspHw frameComplete start
Worker thread CaptureScheduler checkFramePending start
Worker thread CaptureScheduler frameStart start
Worker thread V4L2CaptureScheduler checkCaptureComplete start
Worker thread V4L2CaptureScheduler issueCaptures start
Worker thread PS handleRequests start
getInstance: s_instance(0x7fa0b92570)
subscribe: create SensorType(gyroscope) sensor(0x7fa0b946f0)
subscribe: create SensorType(accelerometer) sensor(0x7fa0b99b50)
AC plugin not present: dlopen “acplugin.so”, acplugin.so: cannot open shared object file: No such file or directory
Services are started
NvPclSetHotplugCallback: ++++++++++++++++++++++
---- Imager: Calibration blob file handling supported in this build ----
CheckProcDTExists: INFO: accessing /proc/device-tree/tegra-camera-platform/modules; No such file or directory
PCLHW_DTParser
NvCamHwHalOpen: Failure to open Camera Kernel Node
NvOdmImagerGetModuleList: Camera node not detected - No such file or directory
NvPclHwGetModuleList: WARNING: Failed to get module header
NvPclHwGetModuleList: WARNING: Failed to get module list from a valid source
NvPclModuleListInitialize: device detection on this platform is not supported
PCLHW_DTParser
NvPclModuleListInitialize: attempting to use backup default module list
NvPclModuleListInitialize: NvPclModule list[0]: GenericModuleSample0 position0
NvPclModuleListInitialize: NvPclModule list[1]: GenericModuleSample1 position1
NvPclHwScanExternalCameras – adding video2 to discover list
NvPclHwScanExternalCameras – adding video1 to discover list
NvPclHwScanExternalCameras – adding video0 to discover list
initialize: /dev/video0
queryControls: 10100740 control HDR enable
queryControls: 10100836 control Bypass Mode
queryControls: 10100837 control Override Enable
queryControls: 10100838 control Height Align
queryControls: 10100839 control Size Align
queryControls: 10100840 control Write ISP format
Ioctl failed: Invalid argument
initialize: /dev/video1
initialize: /dev/video2
q[253063.967242] pgd = ffffffc1ae56f000
ueryControls: 10100839 control S[253063.973680] [00000000] *pgd=000000022cc6d003ize Align
queryControls: 101008, *pud=000000022cc6d00340 control Write ISP format
Ioc, *pmd=0000000000000000tl failed: Invalid argument
get
HotplugMonitor: Getting hotplug monitor [253063.993587] Library at 0x402efc: 0x400000 /usr/sbin/nvcamera-daemon
instance
initializeHotplug++
[253064.003136] Library at 0x402ef8: 0x400000 /usr/sbin/nvcamera-daemon
hotPlugfunc ++
addWatch: Wat[253064.012230] vdso base = 0x7fa72e1000
ch added wd=‘1’
CheckProcDTExists: INFO: accessing /proc/device-tree/tegra-virtual-camera-platform/modules; No such file or directory
PCLHW_DTParser
setHotplugCallback: Registered new callback client
NvPclSetHotplugCallback: ----------------------
hotPlugfunc: reading from inotify FD, Thread waiting
NvPclOpen: ++++++++++++++++++++++
NvPclStateControllerOpen: Found GUID 0 match at index[0]
NvPclHwInitializeModule: allocate overrides pathname @ 0x7fa0bb39b0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7fa0bb3a40
NvPclHwInitializeModule: allocate overrides pathname @ 0x7fa0bb3ad0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7fa0bb3b60
NvPclHwInitializeModule: allocate overrides pathname @ 0x7fa0bb3bf0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7fa0bb3c80
LoadOverridesFile: looking for override file [/data/nvcam/settings/GenericModuleSample0.isp] 6/16CheckOverridesPermissions: cannot stat file [/data/nvcam/settings/GenericModuleSample0.isp]
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/GenericModuleSample0.isp] 7/16CheckOverridesPermissions: cannot stat file [/opt/nvidia/nvcam/settings/GenericModuleSample0.isp]
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/GenericModuleSample0.isp] 8/16CheckOverridesPermissions: cannot stat file [/var/nvidia/nvcam/settings/GenericModuleSample0.isp]
---- imager: No override file found. ----
NvPclCreateDriver: Unable to find a NvPcl Driver name match (s_NVCAM0)
NvPclCreateDriver: Checking legacy driver list…
NvPclCreateDriver: Found a Driver name match (s_NVCAM0)
NvPclCreateDriver: Unable to find a NvPcl Driver name match (f_NVCAM0)
NvPclCreateDriver: Found a Driver name match (f_NVCAM0)
NvPclConnectDrivers: hImager was NULL, creating new imager
NvcImager_Open: Can not open camera device /dev/camera: No such file or directory
NvOdmImagerOpenExpanded 482: Sensor ERR
NvOdmImagerOpenExpanded FAILED!
NvcImager_Close: No hImager->pSensor->pPrivateContext
NvPclConnectDrivers: Failed to open NvOdmImager (735f4e5643414d30, 665f4e5643414d30, 0) - UseSensorCapGUIDS : 0
NvPclConnectDrivers: was unable to create instance of drivers
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7fa0bb3b60
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7fa0bb3bf0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7fa0bb3c80
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7fa0bb39b0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7fa0bb3a40
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7fa0bb3ad0
NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0x4)
NvPclStateControllerClose: Module GenericModuleSample0 closed
NvPclOpen: PCL Open Failed. Error: 0xf
NvPclClose: ++++++++++++++++++++++
NvPclClose: ----------------------
NvPclOpen: ----------------------
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 596)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 781)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 276)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 439)
Failed to start
Freeing pipeline …
[3]+ Segmentation fault (core dumped) nvcamera-daemon
Have a check the context of the /proc/device-tree/tegra-camera-platform/modules/* are as your device tree define.
PCLHW_DTParser
HI ShaneCCC
I’ll ask you again.
No, the sensor_id is the order of the readdir() API to read the /proc/device-tree/tegra-camera-platform/modules/module* and the video node is the order of the i2c bus/slave address.
Why are you struggling with this question? That wouldn’t help on fixing your problem.
I was wondering if I could connect another camera at the same time.
I will not think of that again.
After modifying the device tree, …/…/module was created.
It is the test result after that.
Thread 1 is waiting
Thread 2 is waiting
Thread 3 is waiting
Thread 4 is waiting
Thread 5 is waiting
Thread 6 is waiting
Thread 7 is waiting
Thread 8 is waiting
Thread 9 is waiting
Starting services…
getInstance: s_instance(0x7f94b92570)
subscribe: create SensorType(gyroscope) sensor(0x7f94b946f0)
subscribe: create SensorType(accelerometer) sensor(0x7f94b99b50)
NvPclHwGetModuleList: OFParserListModules Succeeded
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
NvPclHwPrintModuleDefinition – Name: ov16825_hmns
NvPclHwPrintModuleDefinition – Position: 0
NvPclHwPrintModuleDefinition – CalibrationData Found: 1
NvPclHwPrintCameraSubModule – HwCamSubModule[0].Name: v4l2_sensor
NvPclHwPrintCameraSubModule – HwCamSubModule[0].DevName: hmns 2-0020
NvPclHwPrintCameraSubModule – HwCamSubModule[1].Name: v4l2_lens
NvPclHwPrintCameraSubModule – HwCamSubModule[1].DevName:
NvPclModuleListInitialize: NvPclModule list[0]: ov16825_hmns position0
getHotplugMonitor: Getting hotplug monitor instance
initializeHotplug++
hotPlugfunc ++
addWatch: Watch added wd=‘1’
PCLHW_DTParser
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f94bdf100
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f94bdf190
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f94bc3cd0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f94bc3d60
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f94bc3df0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f94bc3e80
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16CheckOverridesPermissions: cannot stat file [/Calib/camera_override.isp]
LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16CheckOverridesPermissions: cannot stat file [/data/nvcam/settings/camera_overrides.isp]
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16CheckOverridesPermissions: cannot stat file [/opt/nvidia/nvcam/settings/camera_overrides.isp]
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16CheckOverridesPermissions: cannot stat file [/var/nvidia/nvcam/settings/camera_overrides.isp]
LoadOverridesFile: looking for override file [/data/nvcam/camera_overrides.isp] 5/16CheckOverridesPermissions: cannot stat file [/data/nvcam/camera_overrides.isp]
LoadOverridesFile: looking for override file [/data/nvcam/settings/ov16825_hmns.isp] 6/16CheckOverridesPermissions: cannot stat file [/data/nvcam/settings/ov16825_hmns.isp]
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/ov16825_hmns.isp] 7/16CheckOverridesPermissions: cannot stat file [/opt/nvidia/nvcam/settings/ov16825_hmns.isp]
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/ov16825_hmns.isp] 8/16CheckOverridesPermissions: cannot stat file [/var/nvidia/nvcam/settings/ov16825_hmns.isp]
Imager: looking for override file [/mnt/factory/camera/factory.bin] 1/16
Imager: looking for override file [/Calib/factory.bin] 2/16
Imager: looking for override file [/Calib/calibration.bin] 3/16
Imager: looking for override file [(null)] 4/16
Imager: looking for override file [(null)] 5/16
Imager: looking for override file [(null)] 6/16
Imager: looking for override file [(null)] 7/16
Imager: looking for override file [(null)] 8/16
Imager: looking for override file [(null)] 9/16
Imager: looking for override file [(null)] 10/16
Imager: looking for override file [(null)] 11/16
Imager: looking for override file [(null)] 12/16
Imager: looking for override file [(null)] 13/16
Imager: looking for override file [(null)] 14/16
Imager: looking for override file [(null)] 15/16
Imager: looking for override file [(null)] 16/16
Imager: looking for override file [/data/nvcam/settings/factory.bin] 1/16
Imager: looking for override file [/data/nvcam/settings/ov16825_hmns.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/ov16825_hmns.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/ov16825_hmns.bin] 4/16
NvPclCreateDriver: Found NvPcl Driver Hal dev[ 396.020520] pgd = ffffffc1b7292000
_name match (v4l2_sensor)
NvPcl[ 396.027066] [00000000] *pgd=0000000250a86003CreateDriver: Found a Driver nam, *pud=0000000250a86003e match (v4l2_sensor)
NvPclCrea, *pmd=0000000000000000teDriver: Found NvPcl Driver Hal
dev_name match (v4l2_lens)
NvPclCreate[ 396.046903] Library at 0x402efc: 0x400000 /usr/sbin/nvcamera-daemon
Driver: Found a Driver name matc[ 396.056414] Library at 0x402ef8: 0x400000 /usr/sbin/nvcamera-daemon
h (v4l2_lens)
NvPclConnectDrive[ 396.065428] vdso base = 0x7f9e754000
NvPclInitializeDrivers: v4l2_sensor ++++++++++++++++++
OFDPropertyGetString: could not read property [devnode-bus]
initialize: hmns 2-0020
(NvOdmDevice) Error ModuleNotPresent: V4L2Device not available (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function findDevice(), line 231)
(NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function initialize(), line 54)
(NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 97)
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
NvPclDriver_V4L2_Focuser_Stub_Close: Invalid NULL input pPclDriver
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f94bc3d60
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f94bc3df0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f94bc3e80
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f94bdf100
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f94bdf190
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f94bc3cd0
NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0xA000E)
NvPclStateControllerClose: Module ov16825_hmns closed
Failed to start
Freeing pipeline …
[2]+ Segmentation fault (core dumped) nvcamera-daemon
Driver code attached.
We implemented the driver code simply because i2c initializes the camera separately in the application.
#include <linux/slab.h>
#include <linux/uaccess.h>
#include <linux/module.h>
#include <linux/seq_file.h>
#include <linux/of.h>
#include <linux/of_device.h>
#include <media/camera_common.h>
enum {
	/* po3100k */
	MNS0000_MODE_1280X720,
	/* ov10635, ap0100 */
	MNS0000_MODE_1280X800,
	MNS0000_MODE_2560X800,
	MNS0000_MODE_3840X800,
	MNS0000_MODE_5120X800,
	/* ar0231 drivepx */
	MNS0000_MODE_1920X1208,
	/* imx323 Kornix */
	MNS0000_MODE_1920X1080,
	MNS0000_MODE_3840X1080,
	/* ov16825 */
	MNS0000_MODE_2304X1728,
static const int hmns0000_30fps[] = {
	    30
static const struct camera_common_frmfmt hmns0000_frmfmt[] = {
	/* po3100k */
	{{1280, 720},	hmns0000_30fps,   1, 0,   MNS0000_MODE_1280X720},
	{{1280, 800},	hmns0000_30fps,   1, 0,   MNS0000_MODE_1280X800},
	{{2560, 800},	hmns0000_30fps,   1, 0,   MNS0000_MODE_2560X800},
	{{3840, 800},	hmns0000_30fps,   1, 0,   MNS0000_MODE_3840X800},
	{{5120, 800},	hmns0000_30fps,   1, 0,   MNS0000_MODE_5120X800},
	{{1920, 1208},	hmns0000_30fps,   1, 0,   MNS0000_MODE_1920X1208},
	/* imx323 Kornix */
	{{1920, 1080},	hmns0000_30fps,   1, 0,   MNS0000_MODE_1920X1080},
	{{3840, 1080},	hmns0000_30fps,   1, 0,   MNS0000_MODE_3840X1080},
	/* ov16825 */
	{{2304, 1728},  hmns0000_30fps,   1, 0,   MNS0000_MODE_2304X1728},
#if 0
#define MNS0000_DEFAULT_DATAFMT		MEDIA_BUS_FMT_UYVY8_1X16
#define MNS0000_DEFAULT_MODE		MNS0000_MODE_1280X800
#define MNS0000_DEFAULT_WIDTH		1280
#define MNS0000_DEFAULT_HEIGHT		800
#endif
#if 0 /* imx323 Kornix */
//#define MNS0000_DEFAULT_DATAFMT		MEDIA_BUS_FMT_UYVY8_2X8
#define MNS0000_DEFAULT_MODE		MNS0000_MODE_3840X1080
#define MNS0000_DEFAULT_WIDTH		3840
#define MNS0000_DEFAULT_HEIGHT		1080
#endif
#define MNS0000_DEFAULT_DATAFMT     MEDIA_BUS_FMT_SBGGR10_1X10
#define MNS0000_DEFAULT_MODE        MNS0000_MODE_2304X1728
#define MNS0000_DEFAULT_WIDTH       2304
#define MNS0000_DEFAULT_HEIGHT      1728
#define MNS0000_DEFAULT_MODE        MNS0000_MODE_1920X1080
#define MNS0000_DEFAULT_WIDTH       1920
#endif
struct hmns0000 {
	int numctrls;
	struct v4l2_ctrl_handler ctrl_handler;
	struct i2c_client * i2c_client;
	struct v4l2_subdev * subdev;
	struct media_pad pad;
	struct camera_common_data * s_data;
	struct camera_common_pdata * pdata;
	struct v4l2_ctrl * ctrls[];
static struct v4l2_ctrl_config ctrl_config_list[] = {
	/* Do not change the name field for the controls! */
		.id = V4L2_CID_HDR_EN,
		.name = "HDR enable",
		.type = V4L2_CTRL_TYPE_INTEGER_MENU,
		.min = 0,
		.max = ARRAY_SIZE(switch_ctrl_qmenu) - 1,
		.menu_skip_mask = 0,
		.def = 0,
		.qmenu_int = switch_ctrl_qmenu,
static int hmns0000_s_stream(struct v4l2_subdev *sd, int enable)
	return 0;
static struct v4l2_subdev_video_ops hmns0000_subdev_video_ops = {
	.s_stream   = hmns0000_s_stream,
	.g_mbus_config			= camera_common_g_mbus_config,
static int hmns0000_get_fmt(struct v4l2_subdev *sd,
		struct v4l2_subdev_pad_config *cfg,
		struct v4l2_subdev_format *format)
	return camera_common_g_fmt(sd, &format->format);
static int hmns0000_set_fmt(struct v4l2_subdev *sd,
	int ret;
	ret = camera_common_s_fmt(sd, &format->format);
	return ret;
static struct v4l2_subdev_pad_ops hmns0000_subdev_pad_ops = {
	.set_fmt = hmns0000_set_fmt,
	.get_fmt = hmns0000_get_fmt,
	.enum_mbus_code = camera_common_enum_mbus_code,
	.enum_frame_size = camera_common_enum_framesizes,
	.enum_frame_interval = camera_common_enum_frameintervals,
static struct v4l2_subdev_ops hmns0000_subdev_ops = {
	.video	= &hmns0000_subdev_video_ops,
	.pad	= &hmns0000_subdev_pad_ops,
static struct of_device_id hmns0000_of_match[] = {
	{ .compatible = "nvidia,hmns0000", },
static int hmns0000_ctrls_init(struct hmns0000 *priv, bool eeprom_ctrl)
	struct i2c_client *client = priv->i2c_client;
	struct v4l2_ctrl *ctrl;
	int numctrls;
	int err;
	int i;
	numctrls = ARRAY_SIZE(ctrl_config_list);
	v4l2_ctrl_handler_init(&priv->ctrl_handler, numctrls);
	for (i = 0; i < numctrls; i++) {
		ctrl = v4l2_ctrl_new_custom(&priv->ctrl_handler,
				&ctrl_config_list[i], NULL);
		if (ctrl == NULL) {
			printk("Failed to init %s ctrl\n", ctrl_config_list[i].name);
			continue;
		if (ctrl_config_list[i].type == V4L2_CTRL_TYPE_STRING &&
				ctrl_config_list[i].flags & V4L2_CTRL_FLAG_READ_ONLY) {
			ctrl->p_new.p_char = devm_kzalloc(&client->dev,
					ctrl_config_list[i].max + 1, GFP_KERNEL);
			if (!ctrl->p_new.p_char)
				return -ENOMEM;
		priv->ctrls[i] = ctrl;
	priv->numctrls = numctrls;
	priv->subdev->ctrl_handler = &priv->ctrl_handler;
	if (priv->ctrl_handler.error) {
		printk("Error %d adding controls\n", priv->ctrl_handler.error);
		err = priv->ctrl_handler.error;
		goto error;
	err = v4l2_ctrl_handler_setup(&priv->ctrl_handler);
	if (err) {
		printk("Error %d setting default controls\n", err);
		goto error;
	return 0;
error:
	v4l2_ctrl_handler_free(&priv->ctrl_handler);
	return err;
MODULE_DEVICE_TABLE(of, hmns0000_of_match);
static struct camera_common_pdata *hmns0000_parse_dt(struct i2c_client *client)
	struct device_node *node = client->dev.of_node;
	struct camera_common_pdata *board_priv_pdata;
	const struct of_device_id *match;
	if (!node)
		return NULL;
	match = of_match_device(hmns0000_of_match, &client->dev);
	if (!match) {
		printk("Failed to find matching dt id\n");
		return NULL;
	board_priv_pdata = devm_kzalloc(&client->dev,
			sizeof(*board_priv_pdata), GFP_KERNEL);
	if (!board_priv_pdata)
		return NULL;
	return board_priv_pdata;
	devm_kfree(&client->dev, board_priv_pdata);
	return NULL;
static int hmns0000_open(struct v4l2_subdev *sd, struct v4l2_subdev_fh *fh)
	return 0;
static const struct v4l2_subdev_internal_ops hmns0000_subdev_internal_ops = {
	.open = hmns0000_open,
static const struct media_entity_operations hmns0000_media_ops = {
	.link_validate = v4l2_subdev_link_validate,
static int hmns0000_probe(struct i2c_client *client, const struct i2c_device_id *id)
	struct camera_common_data *common_data;
	struct hmns0000 *priv;
	char debugfs_name[10];
	int err;
	pr_info("[MNS0000 @ %02X]: Probing V4L2 Sensor.\n", client->addr);
	if (!IS_ENABLED(CONFIG_OF) || !node)
		return -EINVAL;
	common_data = devm_kzalloc(&client->dev, sizeof(struct camera_common_data), GFP_KERNEL);
	if (!common_data)
		return -ENOMEM;
	priv = devm_kzalloc(&client->dev,
			sizeof(struct hmns0000) + sizeof(struct v4l2_ctrl *) * ARRAY_SIZE(ctrl_config_list),
			GFP_KERNEL);
	if (!priv)
		return -ENOMEM;
	priv->pdata = hmns0000_parse_dt(client);
	if (!priv->pdata) {
		printk("unable to get platform data\n");
		return -EFAULT;
	common_data->ctrl_handler	= &priv->ctrl_handler;
	common_data->i2c_client		= client;
	common_data->frmfmt			= hmns0000_frmfmt;
	common_data->colorfmt		= camera_common_find_datafmt(MNS0000_DEFAULT_DATAFMT);
	common_data->ctrls			= priv->ctrls;
	common_data->priv			= (void *)priv;
	common_data->numctrls		= ARRAY_SIZE(ctrl_config_list);
	common_data->numfmts		= ARRAY_SIZE(hmns0000_frmfmt);
	common_data->def_mode		= MNS0000_DEFAULT_MODE;
	common_data->def_width		= MNS0000_DEFAULT_WIDTH;
	common_data->def_height		= MNS0000_DEFAULT_HEIGHT;
	common_data->fmt_width		= common_data->def_width;
	common_data->fmt_height		= common_data->def_height;
	priv->i2c_client 		= client;
	priv->s_data			= common_data;
	priv->subdev			= &common_data->subdev;
	priv->subdev->dev		= &client->dev;
	priv->s_data->dev		= &client->dev;
	err = camera_common_parse_ports(client, common_data);
	if (err) {
		printk("Failed to find port info\n");
		return err;
	sprintf(debugfs_name, "hmns0000_%c", common_data->csi_port + 'a');
	printk("%s: name %s\n", __func__, debugfs_name);
	camera_common_create_debugfs(common_data, debugfs_name);
	v4l2_i2c_subdev_init(priv->subdev, client, &hmns0000_subdev_ops);
	err = hmns0000_ctrls_init(priv, !err);
	if (err)
		return err;
	priv->subdev->internal_ops = &hmns0000_subdev_internal_ops;
	priv->subdev->flags |= V4L2_SUBDEV_FL_HAS_DEVNODE |
		V4L2_SUBDEV_FL_HAS_EVENTS;
#if defined(CONFIG_MEDIA_CONTROLLER)
	priv->pad.flags = MEDIA_PAD_FL_SOURCE;
	priv->subdev->entity.type = MEDIA_ENT_T_V4L2_SUBDEV_SENSOR;
	priv->subdev->entity.ops = &hmns0000_media_ops;
	err = media_entity_init(&priv->subdev->entity, 1, &priv->pad, 0);
	if (err < 0) {
		printk("unable to init media entity\n");
		return err;
#endif
	err = v4l2_async_register_subdev(priv->subdev);
	if (err)
		return err;
	printk("Detected MNS0000 Sensor.\n");
	return 0;
static int hmns0000_remove(struct i2c_client *client)
	struct camera_common_data *s_data = to_camera_common_data(client);
	struct hmns0000 *priv = (struct hmns0000 *)s_data->priv;
	v4l2_async_unregister_subdev(priv->subdev);
	media_entity_cleanup(&priv->subdev->entity);
#endif
	camera_common_remove_debugfs(s_data);
	return 0;
static const struct i2c_device_id hmns0000_id[] = {
	{ "hmns0000", 0 },
MODULE_DEVICE_TABLE(i2c, hmns0000_id);
static struct i2c_driver hmns0000_i2c_driver = {
	.driver = {
		.name = "hmns0000",
		.owner = THIS_MODULE,
		.of_match_table = of_match_ptr(hmns0000_of_match),
	.probe = hmns0000_probe,
	.remove = hmns0000_remove,
	.id_table = hmns0000_id,
module_i2c_driver(hmns0000_i2c_driver);
MODULE_DESCRIPTION("SoC Camera driver for HMNS0000");
MODULE_AUTHOR("Walter Kim <ys.kim@hyundai-mnsoft.com>");
MODULE_LICENSE("GPL v2");
The following is Device Tree.
 * Copyright (c) 2015-2017, NVIDIA CORPORATION.  All rights reserved.
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 2 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful, but WITHOUT
 * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
 * FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License for
 * more details.
 * You should have received a copy of the GNU General Public License
 * along with this program.  If not, see <http://www.gnu.org/licenses/>.
	host1x {
		vi@15700000 {
			num-channels = <3>;
			ports {
				#address-cells = <1>;
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					hmns0000_aggregate_vi_in0: endpoint {
						csi-port = <0>;
						bus-width = <4>;
						remote-endpoint = <&hmns0000_aggregate_csi_out0>;
                port@1 {
                    reg = <1>;
                    hmns0000_aggregate_vi_in1: endpoint {
                        csi-port = <2>;
                        bus-width = <4>;
                        remote-endpoint = <&hmns0000_aggregate_csi_out1>;
                port@2 {
                    reg = <2>;
                    hmns0000_aggregate_vi_in2: endpoint {
                        csi-port = <4>;
                        bus-width = <4>;
                        remote-endpoint = <&hmns0000_aggregate_csi_out2>;
		nvcsi@150c0000 {
			num-channels = <3>;
			#size-cells = <0>;
			channel@0 {
				reg = <0>;
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						hmns0000_aggregate_csi_in0: endpoint@0 {
							csi-port = <0>;
							bus-width = <4>;
							remote-endpoint = <&hmns0000_aggregate_hmns0000_out0>;
					port@1 {
						reg = <1>;
						hmns0000_aggregate_csi_out0: endpoint@1 {
							remote-endpoint = <&hmns0000_aggregate_vi_in0>;
			channel@1 {
				reg = <1>;
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						hmns0000_aggregate_csi_in1: endpoint@2 {
							csi-port = <2>;
							bus-width = <4>;
							remote-endpoint = <&hmns0000_aggregate_hmns0000_out1>;
					port@1 {
						reg = <1>;
						hmns0000_aggregate_csi_out1: endpoint@3 {
							remote-endpoint = <&hmns0000_aggregate_vi_in1>;
			channel@2 {
				reg = <2>;
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						hmns0000_aggregate_csi_in2: endpoint@4 {
							csi-port = <4>;
							bus-width = <4>;
							remote-endpoint = <&hmns0000_aggregate_hmns0000_out2>;
					port@1 {
						reg = <1>;
						hmns0000_aggregate_csi_out2: endpoint@5 {
							remote-endpoint = <&hmns0000_aggregate_vi_in2>;
	i2c@3180000 {
		hmns0000@10 {
			compatible = "nvidia,hmns0000";
			/* I2C device address */
			reg = <0x10>;
			mode0 { //1280x720
				mclk_khz = "24000";
				num_lanes = "4";
				discontinuous_clk = "no";
				dpcm_enable = "false";
				cil_settletime = "0";
				active_w = "1280";
				active_h = "720";
				pixel_t = "uyvy";
				line_length = "1280";
				pix_clk_hz = "74000000";
				min_framerate = "1";
				max_framerate = "30";
				embedded_metadata_height = "0";
			mode1 { //1280x800
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "1280";
				active_h = "800";
				pixel_t = "uyvy";
			mode2 { //2560x800
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "2560";
				active_h = "800";
				pixel_t = "uyvy";
				line_length = "2560";
			mode3 { //3840x800
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "3840";
				active_h = "800";
				pixel_t = "uyvy";
				line_length = "3840";
			mode4 { //5120x800
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "5120";
				active_h = "800";
				pixel_t = "uyvy";
				line_length = "5120";
			mode5 { //HMNS0000_MODE_1920X1208
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "1920";
				active_h = "1208";
				pixel_t = "bayer_rggb";
				readout_orientation = "0";
				line_length = "1354";
				inherent_gain = "1";
				mclk_multiplier = "25";
				pix_clk_hz = "84000000";
				gain_factor = "16";
				framerate_factor = "1";
				min_gain_val = "1";
				max_gain_val = "256";
				min_exp_time = "34";
				max_exp_time = "999994";
				embedded_metadata_height = "24";
			mode6 { //1920x1080
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "1920";
				active_h = "1080";
				pixel_t = "uyvy";
				line_length = "1920";
			mode7 { //3840x1080
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "3840";
				active_h = "1080";
				pixel_t = "uyvy";
			mode8 { //OV5693_MODE_2304x1728
				mclk_khz = "24000";
				num_lanes = "4";
				discontinuous_clk = "yes";
				active_w = "2304";
				active_h = "1728";
				pixel_t = "bayer_bggr";
//				line_length = "2711";
				line_length = "2304";
				mclk_multiplier = "8.5";
//				pix_clk_hz = "160000000";
				pix_clk_hz = "80000000";
//				min_gain_val = "1.0";
//				max_gain_val = "9";
//				min_gain_val = "16";
//				max_gain_val = "192";
				min_gain_val = "1";
				max_gain_val = "16";
				min_hdr_ratio = "1";
				max_hdr_ratio = "64";
				min_exp_time = "20";
				max_exp_time = "327520";
			mode9 { //OV5693_MODE_4608x3456
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "4608";
				active_h = "3456";
				mclk_multiplier = "12.3";
				min_gain_val = "1";
//				min_hdr_ratio = "1";
//				max_hdr_ratio = "64";
			ports {
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					hmns0000_aggregate_hmns0000_out0: endpoint {
						csi-port = <0>;
						bus-width = <4>;
						remote-endpoint = <&hmns0000_aggregate_csi_in0>;
		hmns0000@20 {
			reg = <0x20>;
//			reg = <0x36>;
			devnode = "video1";
			physical_w = "6.239";
		    physical_h = "4.673";
			sensor_model = "hmns0000";
			mode0 { //1280x720
				mclk_khz = "24000";
				num_lanes = "4";
				tegra_sinterface = "serial_c";
				active_w = "1280";
				active_h = "720";
				pixel_t = "uyvy";
			mode1 { //1280x800
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "1280";
				active_h = "800";
				pixel_t = "uyvy";
			mode2 { //2560x800
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "2560";
				active_h = "800";
				pixel_t = "uyvy";
			mode3 { //3840x800
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "3840";
				active_h = "800";
				pixel_t = "uyvy";
			mode4 { //5120x800
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "5120";
				active_h = "800";
				pixel_t = "uyvy";
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "1920";
				active_h = "1208";
				gain_factor = "16";
				min_gain_val = "1";
			mode6 { //1920x1080
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "1920";
				active_h = "1080";
				pixel_t = "uyvy";
			mode7 { //3840x1080
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "3840";
				active_h = "1080";
				pixel_t = "uyvy";
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "2304";
				active_h = "1728";
				min_gain_val = "1";
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "4608";
				active_h = "3456";
				min_gain_val = "1";
			ports {
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					hmns0000_aggregate_hmns0000_out1: endpoint {
						csi-port = <2>;
						bus-width = <4>;
						remote-endpoint = <&hmns0000_aggregate_csi_in1>;
		hmns0000@40 {
			reg = <0x40>;
			mode0 { //1280x720
				mclk_khz = "24000";
				num_lanes = "4";
				tegra_sinterface = "serial_e";
				active_w = "1280";
				active_h = "720";
				pixel_t = "uyvy";
			mode1 { //1280x800
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "1280";
				active_h = "800";
				pixel_t = "uyvy";
			mode2 { //2560x800
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "2560";
				active_h = "800";
				pixel_t = "uyvy";
			mode3 { //3840x800
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "3840";
				active_h = "800";
				pixel_t = "uyvy";
			mode4 { //5120x800
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "5120";
				active_h = "800";
				pixel_t = "uyvy";
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "1920";
				active_h = "1208";
				gain_factor = "16";
				min_gain_val = "1";
			mode6 { //1920x1080
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "1920";
				active_h = "1080";
				pixel_t = "uyvy";
			mode7 { //3840x1080
				mclk_khz = "24000";
				num_lanes = "4";
				active_w = "3840";
				active_h = "1080";
				pixel_t = "uyvy";
			ports {
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					hmns0000_aggregate_hmns0000_out2: endpoint {
						csi-port = <4>;
						bus-width = <4>;
						remote-endpoint = <&hmns0000_aggregate_csi_in2>;
    hmns_ov16825@P5V27C {
        min_focus_distance = "0.0";
        hyper_focal = "0.0";
        focal_length = "2.67";
        f_number = "2.0";
        aperture = "2.0";
	tegra-camera-platform {
		compatible = "nvidia, tegra-camera-platform";
		* Physical settings to calculate max ISO BW
		* num_csi_lanes = <>;
		* Total number of CSI lanes when all cameras are active
		* max_lane_speed = <>;
		* Max lane speed in Kbit/s
		* min_bits_per_pixel = <>;
		* Min bits per pixel
		* vi_peak_byte_per_pixel = <>;
		* Max byte per pixel for the VI ISO case
		* vi_bw_margin_pct = <>;
		* Vi bandwidth margin in percentage
		* max_pixel_rate = <>;
		* Max pixel rate in Kpixel/s for the ISP ISO case
		* isp_peak_byte_per_pixel = <>;
		* Max byte per pixel for the ISP ISO case
		* isp_bw_margin_pct = <>;
		* Isp bandwidth margin in percentage
		num_csi_lanes = <12>;
		max_lane_speed = <1500000>;
		min_bits_per_pixel = <10>;
		vi_peak_byte_per_pixel = <2>;
		vi_bw_margin_pct = <25>;
		max_pixel_rate = <750000>;
		isp_peak_byte_per_pixel = <5>;
		isp_bw_margin_pct = <25>;
		modules {
			module0 {
				badge = "ov16825_hmns";
				position = "rear";
				orientation = "1";
				drivernode0 {
                    /* Declare PCL support driver (classically known as guid)  */
                    pcl_id = "v4l2_sensor";
                    /* Driver v4l2 device name */
                    devname = "hmns 2-0020";
                    /* Declare the device-tree hierarchy to driver instance */
                    proc-device-tree = "/proc/device-tree/i2c@3180000/hmns0000@20";
                drivernode1 {
                    pcl_id = "v4l2_lens";
                    proc-device-tree = "/proc/device-tree/hmns_ov16825@P5V27C/";
The devname should “hmns0000 2-0020”
devname = “hmns 2-0020”;
I modified it as you indicated.
# gst-launch-1.0 -v nvcamerasrc ! 'video/x-raw(memory:NVMM),format=NV12,width=1920,height=1080,framerate
Setting pipeline to PAUSED ...
ERROR: Pipeline doesn't want to pause.
Setting pipeline to NULL ...    nvcamera-daemon   &
[2] 2989
e=30/1' ! nvoverlaysink -evdia# gst-launch-1.0 -v nvcamerasrc ! 'video/x-raw(memory:NVMM),format=NV12,width=1920,height=1080,framerate
Thread 1 is waiting
Thread 2 is waiting
Thread 3 is waiting
Thread 4 is waiting
Thread 5 is waiting
Thread 6 is waiting
Thread 7 is waiting
Thread 8 is waiting
Thread 9 is waiting
Starting services...
getInstance: s_instance(0x7f74b92570)
subscribe: create SensorType(gyroscope) sensor(0x7f74b946f0)
subscribe: create SensorType(accelerometer) sensor(0x7f74b99b50)
AC plugin not present: dlopen "acplugin.so", acplugin.so: cannot open shared object file: No such file or directory
NvPclHwPrintModuleDefinition -- Name: ov16825_hmns
NvPclHwPrintModuleDefinition -- Position: 0
NvPclHwPrintModuleDefinition -- CalibrationData Found: 1
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].Name: v4l2_sensor
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: hmns0000 2-0020
NvPclHwPrintCameraSubModule -- HwCamSubModule[1].Name: v4l2_lens
NvPclHwPrintCameraSubModule -- HwCamSubModule[1].DevName:
NvPclHwScanExternalCameras -- adding video2 to discover list
NvPclHwScanExternalCameras -- adding video1 to discover list
NvPclHwScanExternalCameras -- adding video0 to discover list
 initializeHotplug++
 hotPlugfunc ++
 addWatch: Watch added wd='1'
PCLHW_DTParser
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f74bdf100
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f74bdf190
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f74bc3cd0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f74bc3d60
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f74bc3df0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f74bc3e80
NvPclCreateDriver: Found NvPcl Driver Hal dev_name match [ 6751.289603] pgd = ffffffc1e460d000
(v4l2_sensor)
NvPclCreateDriver[ 6751.295825] [00000000] *pgd=00000002620d4003: Found a Driver name match (v4l, *pud=00000002620d40032_sensor)
NvPclCreateDriver: Fo, *pmd=0000000000000000und NvPcl Driver Hal dev_name ma
tch (v4l2_lens)
NvPclCreateDriver: Foun[ 6751.315750] Library at 0x402efc: 0x400000 /usr/sbin/nvcamera-daemon
d a Driver name match (v4l2_lens[ 6751.325253] Library at 0x402ef8: 0x400000 /usr/sbin/nvcamera-daemon
NvPclConnectDrivers: hImager [ 6751.334278] vdso base = 0x7f7e17e000
initialize: hmns0000 2-0020
OFDPropertyGetString: could not read property [use_decibel_gain]
OFDPropertyGetString: could not read property [use_sensor_mode_id]
OFDPropertyGetString: could not read property [delayed_gain]
OFDPropertyCopyToLong: could not read property [has-eeprom]
Control Fuse ID not found
Control OTP Data not found
Control Group Hold not found
Control Gain not found
Control Frame Rate not found
Control Exposure not found
Control Frame Length not found
Control Coarse Time not found
Control Coarse Time Short not found
checkDriverVersion: Mixed or missing V4L2 controls!
checkDriverVersion: Make sure your kernel driver implements either
checkDriverVersion: V4L2_m_cidFrameLength + V4L2_m_cidCoarseTime(_SHORT)
checkDriverVersion:      or
checkDriverVersion: V4L2_m_cidFrameRate + V4L2_m_cidExposure
(NvOdmDevice) Error BadParameter:  (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function checkDriverVersion(), line 379)
(NvOdmDevice) Error BadParameter:  (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function findCustomCids(), line 309)
(NvOdmDevice) Error BadParameter:  (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initializeV4L2Items(), line 232)
(NvOdmDevice) Error BadParameter:  (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 107)
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f74bc3d60
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f74bc3df0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f74bc3e80
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f74bdf100
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f74bdf190
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f74bc3cd0
Socket read error. Camera Daemon stopped functioning.....
Failed to start
Freeing pipeline ...
The daemon crash problem fixed after modify the devname. But you driver looks like didn’t implement some necessary function.
Have a reference to below link.
“Note: Use either set of controls but do not mix or use both sets at once.”
[url]https://docs.nvidia.com/jetson/l4t/Tegra%20Linux%20Driver%20Package%20Development%20Guide/camera_sensor_prog.html#wwpID0E0FU0HA[/url]
